Amat45v milling machine
Home Forums Introduce Yourself – New members start here! Amat45v milling machine
Viewing 2 posts - 1 through 2 (of 2 total)
  • #731293
    robinstafford
      @robinstafford
      hi l have a Amat 45v milling machine does any one else have a similar machine.l rebuild Vincent motorcycles it has a morse taper head stock is there any way to convert it to a r8 spindle
      John Haine
        @johnhaine32865
        Looks like it’s MT4 taper in the spindle.  I’ve just checked an R8 collet in the nose of my Super 7 big bore which has a shortened MT4 taper and it looks like you could make an adapter though it would need to project a bit from the nose of the quill to provide enough meat at the other end to hold the 24mm parallel bit at the threaded end of the collet.  Some careful drawing needed.  I have made an R8 collet socket for a new Quorn mandrel to hold my R8 collets and a couple of MT4 shanks, so very doable.
