Ama 12 300 v sieg x2
Home Forums Workshop Tools and Tooling Ama 12 300 v sieg x2
  • #161835
    jonathon cary
      @jonathoncary61666
      I had decided to buy a new 12 300 in a few months or a lightly used x2 next door to me now..I think they are virtually identical but the x2 only has a 350 w motor-x12- 550, its 15 kg lighter but slightly larger end mill capacity..Womdered if anyone had experience of an x2 with the smaller motor please..
      thank you..
      jonathon cary
        @jonathoncary61666
        which?!
        #161850
        jonathon cary
          @jonathoncary61666
          I found the threads on the forum and dont want an x2! At least a new amadeal would have a gguarantee .still looking for some older and British that doesnt weightoo much though..
          #161863
          Russell Eberhardt
            @russelleberhardt48058
            Have a look at the Seig sX2P. It has a brushless motor which is much better. It's effectively a three phase ac motor with an inverter control.
            The ratings for endmill capacity have always struck me as somewhat arbitrary. It depends on what you're cutting and how hard you push it.
            Russell.
            #161885
            jonathon cary
              @jonathoncary61666
              Thank you Russel..I am nit entirely happy with electric things at the best of times but all these machines are more than a little prone to problemsand all I would do is spend more money on replacing the whole lot..I have found something though whichcomes with good easy to replace elctrics,belt drive and imperial measurements..It s an Amolco..It will be adequate for the things I intend to do..and stress free..
              #161890
              John Hinkley
                @johnhinkley26699
                Jonathon,
                Just caught up with this thread and had to look up the Amolco mill on lathes.co.uk. I hope you won't be disappointed with it. The table looks minute in the pictures on that site. I have an Amadeal XJ12-300 (if that's what you are referring to in your original post) and, apart from stripping the plastic gears, due to my inexperience, have found it both capable and reliable. I've gradually modified it to my requirements, having fitted a belt drive and 3-axis DRO. It does everything I ask of it and I consider it well worth the money I paid for it.
                Good luck with your new purchase.
                jonathon cary
                  @jonathoncary61666
                  The Amolco doesnt havea table so I can buy one to suit.Only trouble is I havent paid for it yet and am now wondering again..Perhaps I just keep off the forum until I ve got one!
                  #161901
                  John Hinkley
                    @johnhinkley26699
                    I see. It's the bolt-on accessory mill. I'd assumed it was the standalone version with the tables. I hadn't realised that you wanted it to attach to your lathe. What I said about my mill still stands though!
                    jonathon cary
                      @jonathoncary61666
                      I would buy an xy table-I dont have a lathe it would fit..I m sure your mill would make more sense..still not sure though!
                      #161985
                      jonathon cary
                        @jonathoncary61666
                        THATS AMORE
                        When the moon hits your eye
                        like a big pizza pie
                        thats Amolco!!!!
                        Couldnt resist it
                        #161993
                        jonathon cary
                          @jonathoncary61666
                          Given myself a problem now..The Amolco is going to be attached to an ,as yet unbought, xy table which means I ll have to make a bracket of some sort..The best way to do that I suppise is on a milling machine..Aahhh!! Wonder if its worth tryong to find an old Myford lathe bed, grinding it shorter and using a big xy table that fits Myford..I m sure John ,and hope, you will have many years of trouble free milling with your xj12 300 ,I just hope I do!Does anyone know of a big ish milling table that would fit a Myford bed please?
