Aluminium sheet
Aluminium sheet
Home Forums Materials Aluminium sheet
  • #617348
    Speedy Builder5
      @speedybuilder5
      Some time ago, I was given a Good Housekeeping aluminium baking tray – never been used as it was too big for the domestic staff. I had a project in mind for it and cut and folded it etc. I needed to epoxy glue some divisions onto it – but the glue would not bond. Cleaned the joint area with alcohol and re-glued the joints. Still no joy and then I assumed that the hard anodised finish was in fact some sort of non-stick finish which certainly worked !
      Moral of this text – not all material is what it seems!!
      Bob
      Speedy Builder5
        @speedybuilder5
        Aluminium sheet coatings
        #617354
        David George 1
          @davidgeorge1
          I used to make aluminium mould parts for making plastic gas pipe fittings and they were hard anodized and PTFE coated to prevent wear as they were pulled from the plastic part after moulding.
          David
          #617360
          John Rutzen
            @johnrutzen76569
            I bought some hard anodized aluminium sheet and tried to spray paint it with etch primer for aluminium, the paint just fell off! You have to sandpaper it with fairly coarse stuff to get a key. Another piece of bare aluminium was ok.
            #617361
            not done it yet
              @notdoneityet
              SB5,
              If those dividers were aluminium the ‘alutite’ (on sale at the exhibition) might be an ideal method of attachment.?
              I replenished my stock on Thursday, so that I don’t have to be so stingy in choosing to use it, for a while.🙂
              #617375
              Grindstone Cowboy
                @grindstonecowboy
                I believe most modern baking trays do come with a non-stick PTFE coating.
                Rob
                #617379
                roy entwistle
                  @royentwistle24699
                  How do they stick the non-stick coating on? cheeky
                  #617384
                  larry phelan 1
                    @larryphelan1
                    How do they get the figs into the fig rolls ???cheeky
                    #617387
                    Grindstone Cowboy
                      @grindstonecowboy
                      And how do they do those pork pies with an egg in the middle and in every slice the egg is the same size?
                      (I know the answer, but it might spark discussion devil)
                      Rob
                      #617394
                      Baz
                        @baz89810
                        Posted by Grindstone Cowboy on 15/10/2022 12:13:40:
                        Rob
                        Specially bred chickens that lay continuous eggs?
                        #617412
                        pgk pgk
                          @pgkpgk17461
                          Instead of allowing them in the henhouse you get them to lay by the yard.
                          Note: you can boil eggs in a kettle but you can't pour them out.
                          #617415
                          duncan webster 1
                            @duncanwebster1
                            Pressed the wrong button
                            Edited By duncan webster on 15/10/2022 15:28:28
                            #617497
                            Baz
                              @baz89810
                              Grindstone Cowboy, I had to take her indoors shopping yesterday and we visited a Marks and Spencer’s food hall, I made a point of looking at their slices of pork pie with egg in the middle and they were using proper eggs, one slice of pie was an end piece and the other a middle bit with yolk. Being a rather sad person I checked all the packs on display and they were the same, obviously Marks and Spencer need to be informed of the continuous egg process, come on, spill the beans!
                              #617502
                              Grindstone Cowboy
                                @grindstonecowboy
                                Well, I read an explanation of it in a Reader's Digest "How Do They Do That?" type book many years ago, and it involved various metal tubes and rods (but luckily for the chickens AFTER their input has ended).
                                Firstly, the whites are cooked in a tube with a central rod, forming an egg white cylinder, then the rod is extracted and raw yolk inserted and cooked. So you have, effectively, a very long egg which can be cooked into the pie.
                                Full marks to M&S (no pun intended) for not going fully industrial.
                                Why don't chocolate chips in chocolate chip cookies melt when they are being baked?
                                Rob
                                #617521
                                Anonymous
                                  Posted by larry phelan 1 on 15/10/2022 12:00:24:
                                  How did they get the tube-trains down the escalators?
                                  (they took them down in pieces and reassembled them).
                                  #617529
                                  mark costello 1
                                    @markcostello1
                                    They are tough chips, They can take the heat?
                                  Home Forums Materials Topics
