Well it does depend on the size of the engine of course but not knowing anything about motor cycle engines I’ll abstain on that front.
A model I/C engine however is a different matter and using He15 -2014 as others have suggested is ideal. I did have a supply of very tough aluminium called Alumec 89 which is around the 7075 grade as Bernard has used and this has proved successful too. Alas the supply for that has now ceased 🙄
Unless the rod is very small at the big end I usually fit a bush made from drawn phosphor bronze. Though it is recognised that this material should only be used if a ‘shaft’ is hardened due to the potential of ‘pick up’ I have found no issue with it on EN24T in it’s as machined state in the engines built to date.
If the rod/section is small or slight then steel can be used but it really ought to be bushed if running on an unhardened steel crank pin
Tug
