@Rod,
Don't forget that without the 69.00 Euro license fee Nigel is restricted to 25 lines of Gcode.
@sam
You say that 5i25/7i76 is an over the top combination and go on to mention that a 7i92 is all that you need, yet this is the combination most mentioned anywhere I look for information on what Mesa boards to use.
I have re-read the description and manual of the 7i92 and yes, it would appear that it can be used stand-alone parallel port replacement – it would still need some form of breakout board even if it is a basic $4.00 Chinese one, since most home-brew conversions aren't parallel port ready
This also re-affirms my earlier point about it being difficult for someone new to work out what Mesa cards they need – no guidance on Mesa's own site, the LinuxCNC Wiki is amazingly vague on the subject, merely mentioning a large number of possibilities that should work and doesn't even mention the 7i92 card!
If I specifically search for the 7i92 card, I see very few posts about it, and many of those I do find are from the LinuxCNC forum which seem to be cries for help with using one – hardly a great advert.
To buy one I would need to order from the US, not necessarily an issue, but Mesa quote 6-8 week lead times, EUsurplus have no stock, and I have yet to find a UK supplier.
I like the idea of this board in that it de-couples from the required PC, making some form of laptop more of an option, or a mini PC that can fit behind the monitor.
One thing I am not so keen on with the Mesa breakout boards is that their screw terminals are too close to each other to use crimped ferrules, and pretty awful from a strain relief point of view – 90 degree plug in screw terminals would be a better option in that regard.
Edited By Zebethyal on 07/10/2016 09:33:53
