Reply mainly to Jal but also to anyone else who's interested.
OK managed to get to a computer as opposed to my phone which is so limited for reading and replying.
First for Jal's sake a bit of history. I have been involved with CNC and conversions from around 1995 and total conversions must be well over 100 by now and this is from hobby the mid sized industrial. Add to this I have been deeply involved in design and development and support of the Sieg KX1 and KX3 model with a bit on the KC4 and KC6 lathe. No idea what total sales are on these, only Sieg knows, but have to be in the high thousands.
On the Sieg side I also deliver and setup machines for users who cannot do this, provide training and up until a few years ago we used to attend shows round the UK where we ran the KX1 and KX3 under power and spoke to people. We also did lectures on the advantage of CNC and other issues.
The end result is I have a decent understanding of the hobby / small industrial market.
Now I have read the documentation and it's raised some questions but firstly let me apologise for the error on thinking it contained drivers.
First thing I'd like to point out is when they compare Masso to what's out there are regards PC's
They say for the PC "Initial setup and wiring is time consuming and requires specialist skills" and compared to the Masso " Unbox, plug in and GO!!"
I think this is grossly unfair and a poor comparison because the drivers, limit switches spindle etc do not wire them selves up. The only thing you can plug in is a keyboard and monitor.
So first views of the screen and what I wrongly called the OS, reasonably laid out if anything a bit sparce given that the graphics take up most of the allocated room. Why that is I don't know because if you don't know what you are cutting before you start you should not be stood in front of a machine.
Wizards, and yes what a horrible name. It's conversational programming, why not call it such. Masso puts emphasis on "Industrial grade " and then uses a naff term like Wizards ?
They are quite crude. Threading wizard for example needs to know the OD of the thread, start end length and pitch which is fine, then it need to know the root diameter of the thread. Who has that to hand, what's wrong with a drop down box populated with the most popular threads and allow it to use these values ?
Mill wizards, again crude to the extent that bolt hole circle is missing.
G Codes, very few exist. No G41 /G42 tool off set, No G43/G44 tool length off set. No G53 to G59 codes although you can set an off set in the tool table but can't call it via G code.
Lathe threading is G32 only, no G76 or G92 so no control over infeed angles or pull out.
Two years ago if correctly priced it could have been a breath of fresh air on the scene but at this point in time I feel it's too little to late with what is coming out of China.
Ok it has far more features than the £150 Chinese 4 axis controller but it's a lot more money.
Retail of this for a mill is $717 AUS which on todays rate works out to £423 UKP, add £30 for shipping, £15 for DHL / Fedex handling and £87.60 VAT and you have a total of £561.60 Now add monitor and keyboard etc and you have about £700 UKP
So if you want a cheap solution £150 will give it you and if you want true Industry standard with all in one box then this will do the job.
Direct from the factory these are about £450 to £480 landed and duty paid.
Edited By John Stevenson on 02/10/2016 17:39:45
