LOL! Thank you for your forthright advice.
Forgive my ignorance but in what context are band saw blades 4″ round please?
I have tried google and i don’t get convincing answers
I agree with Larry and Howard. My generic bandsaw, which came from Warco (a CY90), is the roughest machine tool I ever bought! However, it’s also the most useful, because it removes the need for tiresome tedious hack-sawing.
Mine arrived with a cheap carbon-steel blade that didn’t last long or cut straight. Replacing it with a bi-metallic blade made an immediate improvement though the blade still tended to cut slantwise Fixed by carefully adjusting the blade tension and rollers, which required some fettling of the metalwork – as delivered, the rough casting did not quite allow enough tension travel, and I vaguely remember tweaking one of the rollers too. Both drive wheels were marred by the remains of a moulding line. All easily fixed with a file, and resetting, since when I’ve not had to touch it apart from mending a gearbox cover leak: this also due to a minor casting fault, mended with blue gasket stuff.
The need to fettle this class of saw isn’t uncommon, and not everyone is comfy doing it: many hobbyists prefer making things to mending their tools! I took the line that improving the saw was a learning opportunity.
The generic saw’s advantage is low cost, less than half that of the least expensive alternative. But it might need attention. FEM saws have a good reputation, but bear in mind they’re inexpensive too! Industrial saws are designed for years of hard accurate cutting and cost thousands. Second-hand industrial is an option, but their condition is all important. In my view, a cheap hobby saw needing minor fettling is a better bet than a worn-out high-end saw needing lots of repairs and expensive parts.
