On
10 August 2024 at 09:59 JasonB Said:
As these feeds get fitted to machines with both metric and imperial leadscrews there is no specific revs per mark.
That does not seem correct as a statement. The ‘language’ of the screw is irrelevant to the motor and its controller.
Indeed, you would expect ‘5’ on the motor to give the SAME rpm whatever it is fitted to.
Hence, I would say there most surely is a specific rpm for each mark. The rpm increment between marks is likely to be non-linear, as pointed out above.
The feed rate produced by setting the dial to any particular mark will of course be dependent on the pitch of the screw to which it is attached.
A modern option is a tachometer app for your phone. See what the app needs as a reference and let it tell you the motor rpm for each dial division. Factor in your leadscrew pitch to calculate a feed rate.
