Alpine Engineering bench drill
Home Forums Manual machine tools Alpine Engineering bench drill
  • #12763
    sparky mike
      @sparkymike
      sparky mike
        @sparkymike
        Hi. In the 80's I bought a large 12 speed bench drill from Alpine Engineering.
        (are they still in existance.) It has been used daily for many years now, until the other day when it developed a faint rattle. It took me a few minutes to work out what was wrong, and after removing the belts, I found that the screws (that hold on the belt guard )under the quill pulley were working loose. I managed to tighten one of them up with the aid of some needle nose vice grip pliers,but the other was missing and possibly never fitted. it would be prudent to check the screws on these Chinese drills, before they ride up and possibly jam the pulley wheel.
        I undid the large nut that holds on the pulley wheel for easier access to the screw/s but could not shift the pulley, so left well alone. The nut was left handed.
        Mike.
        Edited By sparky mike on 07/09/2016 07:42:20
        #254502
        Russ B
          @russb
          If it's the one I'm thinking of, very similar (probably the same) machines were also branded as (roughly chronologically) – Pinnacle, Nutools, and are still sold as Clarke.
          Clarke parts diagrams are freely available online, I would perhaps start looking there. I expect minor cost saving over the years will have removed some parts but it could help.
          #254519
          john fletcher 1
            @johnfletcher1
            I had a bench top Alpine and the front pulley was on a taper, I used a bit of heat to release it. Following an article in ME several years ago, I took the machine to pieces as the there was a lot of slop in the spindle /rack. I made two eccentric bushes and Loctite them in place, transformed a cheap modest machine. I also have one of their band saw for cutting steel, must be more than 30 years old, it just keeps rolling along. John
            #254521
            sparky mike
              @sparkymike
              Only drawback I have had so far is that the threads are a bit short and slack on the three rod operating handle.
              Not sure if there is room for helicoils.
              Mike.
              #254624
              sparky mike
                @sparkymike
                I just checked my other , much smaller Chinese bench drill and the guard screws were loose, so this sounds like a common fault. I have refitted the screws with lock washers. Originally only plain washers were used.
                Mike.
                #254675
                julian atkins
                  @julianatkins58923
                  Hi Mike,
                  Graham Engineering of Aston Road Birmingham…just off Spaghetti junction…
                  I am pretty sure they went out of business many years ago.
                  My first engineering stuff bought was from them in 1983. The 3 files have long ceased to cut, but the engineers square and hacksaw frame, and bench vice are still in daily use.
                  Hope you get the mill sorted.
                  Cheers,
                  Julian
                  #254730
                  Tim Stevens
                    @timstevens64731
                    My guess is that Julian's post (23:08:46) is in the wrong place. Too near to midnight? …
                    Tim
                    #254734
                    julian atkins
                      @julianatkins58923
                      Hi Tim,
                      Unless I am mistaken, 'Alpine' was the branding of the products sold by Graham Engineering at the time Mike bought his mill.
                      Cheers,
                      Julian
                      #254746
                      sparky mike
                        @sparkymike
                        I bought a drill not a mill !!
                        #254755
                        Bazyle
                          @bazyle
                          The other Graham brother set up on the other side of Birmingham and I think is still there. At one time in ME they each ran the same advert artwork in alternate issues but you had to look at the address to see which one it was.
                          #254760
                          Vic
                            @vic
                            Some of the early Far East imports were Korean or Taiwanese rather than Chinese.
                            #254763
                            Russ B
                              @russb
                              Posted by Vic on 08/09/2016 14:05:49:
                              Mines Taiwanese, I would be interested to see some Korean stuff, so far everything I've had from Korea has been excellent quality (rifle scopes, engines, electronics)
                              #254765
                              daveb
                                @daveb17630
                                Posted by Russ B on 08/09/2016 14:15:20:
                                Look at anything from NAEROK.
                                Ajohnw
                                  @ajohnw51620
                                  Posted by julian atkins on 08/09/2016 11:37:46:
                                  Hi Tim,
                                  Cheers,
                                  Julian
                                  It was Julian mill or drill. They had 2 outlets. The one that sold machines was in West Bromwich. A large showroom. The other was by Spaghetti Junction. Much smaller place. From what I could gather the owner retired and that closed the main showroom. The much smaller shop survived and was run by one of his sons. I think that ended when the owner died.
                                  They were a pretty big name in their day. At one time they used to have a VAT free day once a year and masses of model engineers used to turn up at West Brom in coaches. Could hardly move in the place at times.
                                  They initially imported some stuff from India including Super 7 clones. Later Taiwan and later still China. They used to sort out the old from India stock for me if there was any left. Some of the blokes there reckoned they did thing properly as we taught them how. I think I might be inclined to agree going on the quality levels of bits and pieces I bought. i think they were the 1st to go to Toss for chucks too.
                                  Edited By Ajohnw on 09/09/2016 20:22:17
                                  #254997
                                  julian atkins
                                    @julianatkins58923
                                    Thank you John and Bazyle.
                                    You have both confirmed my memory, even if my short term memory cant remember a drill from a mill!
                                    Cheers,
                                    Julian
                                    #255025
                                    sparky mike
                                      @sparkymike
                                      I am pretty sure I still have one of their comprehensive catalogues here somewhere. There was not much in the tool line that they did not sell.
                                      Re. Chinese, after the memory was jogged a bit I believe it was from Taiwan and not China.
                                      Mike.
                                      #255539
                                      Jon
                                        @jon
                                        Just an addition Graham west Brom definitely were slowing down in 98, 99 reduced its store area around 1/3 with little machine tools on display. With the setup of J&L nearby taking a top staff member it didn't survive long after approx.1999 when picked up a Vertex RT and some proper Eclipse Cobalt 5% HSS tools getting feeling selling up.
                                        Alpine was the brand name applied to anything produced any where in the world. Best seller for them was the RF25 Chinese and the flimsy bandsaws.
                                        Been past Graham Eng Wolvo many times bought drill from there in 92 never used since, thought they had closed decades ago apparently not in local directories. Both brothers didn't get on a sore subject.
                                        Now know still going despite appearances driving past seeing clear parking area and closed doors might pay him a visit next month. Used to flog s/h quality English tools and decent foreign quality tools with new chinese.
                                        #255556
                                        Ajohnw
                                          @ajohnw51620
                                          The Chinese stuff came later than Taiwanese and that was later than Indian. The Taiwanese had the bright idea of not using hardened bearings in the small lathe headstocks. They sold very few and a fair few of the early Chinese combined mill drills which had all sorts of alignment problems – I know I bought one – big mistake but eventually sold it to some one that didn't care. There stock answer to the alignment problems was to send people to another small engineering supplier for shims which they didn't stock. The man there mentioned that they kept sending people there for shims, a number of them. The man who dealt with machine sales was a little more honest with me after that. When I bought tooling the guys behind the counter would always try and sort out old from India stock.
                                          I suspect it closed because there was more competition especially on smaller lathes and odd bits an pieces also the owner was getting on. A lot of the stuff that came out of China at the time was rubbish. Things seemed to get better when lathes like the CT918 arrived. Some of the lathes of that period are a lot heavier built than now but the geahead version for instance is incredibly noisy. They might even have a screw cutting gearbox.
                                          First thing I knew about them closing in West Brom was when I went over there to buy some bits and pieces so I then used the smaller one by Spaghetti Junction. Same happened there. I was told that the father died which meant that the shop had to be sold as he owned it. Maybe the same in West Brom in which case there may be something else in there now. I do know that it was still empty a some time after it closed but haven't bothered looking for a long long time.
                                          I found out that Reeve's at Marston Green had closed following a visit to get some steel. I had heard that their casting sales were way down and that was causing them problems as it was a major proportion of their sales. Sad really because they only sold good stuff in the general tooling line but of course that costs more. The steel they sold was excellent a well. It does vary.
                                          Actually I think both of these companies realised that the writing was on the wall as the saying goes.
                                          Brian H
                                            @brianh50089
                                            I have an "ALPINE" mill/drill, serial No 15. My only complaint is that it needs several different lengths of belt to obtain all the speeds.
                                            I must check on the screws that were mentioned in the first post.
                                            #255569
                                            sparky mike
                                              @sparkymike
                                              As a post script, I just found the "Graham" catalogue and company name had been changed to" Tooling Direct.(incorporating Graham Central and Tooling Direct.) "
                                              No idea what year the catalogue is, but Edition 22 is on the cover.
                                              Address was 533/537 Lichfield rd. Birmingham.
                                              Mike.
                                              #255578
                                              Trevorh
                                                @trevorh
                                                Hi Mike
                                                I have the Alpine Mill Drill machine and had the same problem as you, you can get access to the cap heads by cutting down an Allen key almost onto the bend, then with the middle set of pulley's removed you can get to all of the screws that hold the Bottom half of the guard in place
                                                hope this helps
                                                Trevor
                                                #255597
                                                Ajohnw
                                                  @ajohnw51620
                                                  Google street view shows 533/537 Lichfield Rd as I last saw it. Roller shutter door shut. Next time I need some none ferrous I will look and see what's there now. My version of what happened there came from one of the neighbours. I asked because I wondered if they were just closed for the day. Seems they had been shut for some months.
                                                  It's a pity one of the newer retailers didn't move into their West Brom shop. Close to the M5, decent size and access to a fair proportion of the UK population.
                                                  I also found a tooling retailer in Redditch. Modern shop in a sort of high street area. sad I can't find it again. It may have gone. Circa 15 years ago or more there was all sorts around in B'ham due to the nature of the area. Most has gone. There is still a used machine tool dealer within a mile or so but these days they only sell BIG stuff. Others too just a bit further away but the days when they also had equipment about seems to have gone. A few sold little else. They went even longer ago.
                                                  laughAt least Rotagrip is still going but at some point he might retire.
                                                  Ajohnw
                                                    @ajohnw51620
                                                    Posted by Trevorh on 13/09/2016 09:02:57:
                                                    Hi Mike
                                                    hope this helps
                                                    Trevor
                                                    I'd guess that has round column and belts. It's always interested me that people buy the different style when that one is still available from Warco. It's a pretty powerful machine – belt drive, not so easy to change speed but if I bought new it would be what I would get maybe in 3 phase to get SOME speed variation via a knob.
                                                    As things are I haven't got space for a motor hanging out of the back even on my DW.
                                                    Edited By Ajohnw on 13/09/2016 11:07:57
                                                    #255601
                                                    Trevorh
                                                      @trevorh
                                                      Hi John, Yes thats the one, the DM 50, it is a bit of a beast and not the easiest to work on,
                                                      I have already had to fit new spindle bearings and getting the drive pulley's off needed a lot of Persuasion with pullers and pry bars.
                                                      But having a MT 2 taper means I can cover most sizes, I am actually going to the show this weekend to look at down sizing to a WM16 or similar but want to have a look at the actual machine to get a feel for it
                                                      cheers
                                                      Edited By Trevorh on 13/09/2016 11:24:25
