Alloy corrosion
Alloy corrosion
Home Forums General Questions Alloy corrosion
  • #22093
    Kenneth Deighton
      @kennethdeighton43272
      Kenneth Deighton
        I am restoring a pair of garden lamps, the alloy castings are very corroded, what treatment should I give them before I paint them? Ken.
        #90344
        Gray62
          @gray62
          depends on how bad the corrosion is, but, if you want to restore a smooth finish, then I would suggest using a flexible car body filler such as P38 or U-Pol. Both are easy to sand to shape and will bond well to alloy castings.
          CB
          #90374
          Sub Mandrel
            @submandrel
            Hi Ken,
            If they are whitemetal castings with a white powdery bloom, this could be tin oxide. Tin oxide catalyses its own spread so it's a good idea to get as much off as you can with a stiff wire brush then use zinc oxide primer before painting.
            Kenneth Deighton
              Thankyou for your thoughts , it is a "chemical " solution that I was looking for such as Jenolite, as the finnish need not be as good as body work etc as they will only be in the garden.
              #90376
              KWIL
                @kwil
                Shot blast them and paint immediately before the dreaded white powder comes back.
                #90386
                Peter Tucker
                  @petertucker86088
                  Hi Kenneth,
                  If the corrosion is bad I would recommend you whip up a model and re cast the fittings.
                  Peter.
                  #90389
                  thomas oliver 2
                    @thomasoliver2
                    I would be interested to know how tin oxide would form on alloy castings. Alloy cleaner for car wheels can be obtained at autospare shops. I have a 6in powered wire wheel which is very efficient for such work. It is good on paint jobs as well. Tomol.
                    #90392
                    Sub Mandrel
                      @submandrel
                      Hi Thomas,
                      'alloy' mean any mixture of metals, not just aluminium and magnesium alloys isued for car parts. I have some garden 'coach style' lamps and they appear to be 'white metal' – name for a wide range of low melting point alloys that are mostly tin with varying amounts of lead, copper antimony and other metals. Think Dinky/Matchbox cars (at least the old ones, I expect the new ones are lead free).
                      As Peter suggest the melting point is usually low enough that they can be easily melted with a blowlamp.
                      Deltic007
                        @deltic007
                        I would lightly blast off and apply a good etch primer straightaway then either powder coat of wet spray and make sure you get over 300 microns of paint or powder on.
                        #90394
                        Deltic007
                          @deltic007
