Allchin 1.5″ Injector Options
Home Forums Traction engines Allchin 1.5″ Injector Options
  • #449634
    Howard Atkins 1
      @howardatkins1
      Hi,
      What's the preferred injector for the Allchin 1.5" Royal Chester?
      I'm replacing the injector on my fathers Allchin, should I buy a standard size 2 injector or the 'Allchin' injector from Polly Models?
      Howard Atkins 1
        @howardatkins1
        #449642
        Clive Brown 1
          @clivebrown1
          As specified in the original Hughes' design, the injector has a side inlet for the water. The Polly injector might have that feature whereas most commecial offerings don't AFAIK. However, I 'm not suggesting that side entry is essential.
          #449669
          Nick Clarke 3
            @nickclarke3
            In the re-run of the series in the 1970's W J Hughes noted that the original injector was taken from LBSC's 3 1/2" loco Petrolea – if that gives you any idea of the capacity required??
            #449720
            julian atkins
              @julianatkins58923
              Hi Howard,
              Suggest you contact Paviersteam, usual disclaimer, though currently the website omits the previous extensive list of Len Steel injectors to the Gordon Chiverton designs, so I don't quite know what has happened recently.
              What is wrong with your father's original injector fitted?
              I recall Bill Hughes stating he was going to describe the injector for 'Royal Chester', but I don't think he ever did. I thought I had a complete set of MEs for 'Royal Chester', but I might have missed an issue, as I am not that interested in miniature traction engines generally.
              Cheers,
              Julian
              #449732
              Nick Clarke 3
                @nickclarke3
                Posted by julian atkins on 29/01/2020 21:28:08:
                Cheers,
                Julian
                That sound like the mag i was reading by chance the other day – He mentioned the Petrolea reference to his original articles and that he had drawn up his own design in the 1970's but he had not yet traced it and had prints produced and readers were not to write in for them yet. It may never have happened.
                #449785
                Howard Atkins 1
                  @howardatkins1
                  Thank you for all your replies, very helpful.
                  Polly models 'Allchin' injector has a side inlet for the water.
                  As for the original injector this has been machined incorrectly, it will not function and modification to suit would be rather difficult.
                Home Forums Traction engines Topics
