Posted by mike T on 17/04/2017 13:01:18
A 4 hour 24000 RPM or a 20 hour 5000RPM machining job, does not sound like 'normal' model engineering work to me.
Who said I was normal?
The high speed spindle is self-contained (ER11) and not quick change, which has the problem of not being able to use tool tables. To save people the bother of looking, here are the parts mentioned; as Jason says 16 tooth 16DP bevel gears for my traction engine governors:
![governor bevel gear cnc.jpg governor bevel gear cnc.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
![governor bevel gears me.jpg governor bevel gears me.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
When starting in CNC milling I used relatively large cutters with commensurately slow speeds. Given that my CNC mill is not the most rigid of machines I eventually fell in that maximum metal removal rates were best achieved with smallish cutters running fast and at high feedrates. Although my CNC mill has two belt driven ranges, the basic drive is via a VFD. So more spindle power is available at the higher end of the speed ranges; equals better metal removal rates.
