Just bought the 2.5hp compressor from Aldi last week as my current one is much smaller
Anyway the two airline connectors are "Euro quick" – which seem to be the same as 1/4" BSP as on my small one but I just thought I would check on here as connectors of this size don't seem to fit tightly when test fitting my air tools. I need to order two airlines and want to make sure I order the correct ones.
Also I bought a Snap On die grinder from a fellow motorcycle forum member but it doesn't have a connector on it. The female thread is 1/4" NPT which is 19 tpi and the same size BSP is 18 tpi and I have read not to mix the two. Where can I buy a connector which has the right female thread for the grinder but a "normal" BSP or Euro quick connector at the other end?
What I thought I needed to buy were two airlines with Euro quick connectors at the compressor end and 1/4" BSP at the other end for my air tools but I'll hold fire until you chaps can better inform me
Thanks for any help. I hope this doesn't incite any "what the hell is this question doing on a model engineering forum?" responses as I have tried to express it clearly in the title and description and choice of topic area
