Aldi Calipers…
Aldi Calipers…
Home Forums Workshop Tools and Tooling Aldi Calipers…
Viewing 8 posts - 51 through 58 (of 58 total)
  • #347259
      Posted by Alistair Robertson 1 on 23/03/2018 15:43:18:
      I bought a couple of these digital verniers from Aldi in April/May last year.
      I used one last week and noticed that the display was adding 0.200" to the total when I moved
      Anyone else have similar problems or is it just a one off problem and I should probably put in our electronic waste box.
      Alistair
      I've got a scale that jumps exactly like that when the battery is on the way out.
      I don't think it's a coincidence that 0.2" is 5.08 mm and 5.08 x 25 is 127. As 127 is a magic number in binary I think it's a clue that the digital scale is misread either because dirt or damp is upsetting the read head, or because a decrepit battery is upsetting the electronics.
      It's quite likely that a cheap caliper will come with a cheap battery. As Aldi/Lidl sell remainders, it's also quite likely that a caliper bought from them is 'New Old Stock'. Don't expect too much of the batteries.
      Edited By SillyOldDuffer on 23/03/2018 17:45:50
      Ian Parkin
        @ianparkin39383
        what do you mean by remainders?
        #347263
        John Haine
          @johnhaine32865
          I don't know about Aldi ones, I have a Baty one that's hardly used and does that even with a good battery. Grrr…
          #347292
          ChrisH
            @chrish
            I have given up on digital calipers, wherever from, – not really due to battery life, more down to erratic readings – the digital ones I have owned seemed to have an undesirable 'snowflake generation' side I couldn't cope with.
            I now have gone back to vernier calipers for rough work, or work that doesn't call for really accurate measurement, and micrometers when accuracy is required. OK, it may be a tad slower, I'm a slow worker anyway so no odds there, but it is always reliable, and they don't fail just when I need it most. And I can trust them!
            Chris
            #347301
              Posted by Ian Parkin on 23/03/2018 18:12:15:
              Remainders are what's left over after an supplier has satisfied demand. In the wholesale world almost every large transaction results in a small surplus becoming available. Say you contract to supply 100,000 calipers. You allow for a percentage to be faulty or damaged in transit, and order an extra 10%. When they arrive it turns out that they're all good, so you're left with 10,000 extras. As warehousing is expensive and you've already achieved your profit target it pays to remainder them, that is to sell them on cheap. Another other way is when your customer orders 100,000 calipers and then goes bankrupt just before taking delivery. Or you buy 100,000 tons of cornflakes only to find that Muesli unexpectedly becoming fashionable has left you stocking an unwanted 5000 tons. On the domestic scale, you might save surplus material in your shed; in commerce overstocking is bad news because the space is needed for the next consignment of whatever.
              There are many other reasons for small to moderately large quantities of goods to appear on the market and it's possible to make a good living by sweeping up surpluses and selling them on. That's partly what Aldi and Lidl do. Compared with Tesco, ASDA etc, what they stock is somewhat erratic but that's compensated for by bargains and surprises.
              Most of the trade in remainders is above board but it can be pretty shady around the edges. Armaments, banned chemicals, ivory, rotten baby milk and time-expired pharmaceuticals all have a bad habit of turning up where they shouldn't. The rules are strange too. Trying to buy a government surplus assault rifle makes me a criminal; if I sell a million of them and contribute to party funds I'll probably be rewarded with a knighthood!
              Edited By SillyOldDuffer on 23/03/2018 23:09:25
              #347353
              larry Phelan
                @larryphelan54019
                I too have a few of those cheap ones from Aldi/Lidi,s and I find them OK. I also have a Mitutoyo which I got for nothing,but I dont leave that lying around the workshop.
                I have found that neither these calipers nor welding rods like cold,damp workshops,so I solved the problem by keeping both items in my hot press until required [at this time of the year,I keep my butter there as well,since coming from the fridge,it,s as hard as a brick ] Everything seems to get along fine and the rods are dry when I need them [damp rods are a PITA ] It,s just a question of remembering what you,ve gone to the hot press for,not always easy when you get on in years !
                As someone said,at that price you can,t expect Grade A,but they do work well enough for those of us whose eyes are no longer Grade A.. A s one of my mates said,"What,s a few thou between friends?"
                Anyway,they look good,even if you dont know how to use them !!!
                #347357
                Nick Hulme
                  @nickhulme30114
                  I have a pair of Lidl/Aldi Digital Calipers on each machine and bench in my garage and workshop, but only the ones with a single Lithium Ion cell, the cells last for years, I haven't had to replace a Lithium Ion cell or caliper yet.
                  They all check out well against my Mitutoyo inspection grade gauge blocks with good accuracy and repeatability, the first thing I do is wipe them clean, move the head to the opposite end, wipe clean and repeat a few more times then wipe with a lightly oiled cloth, then they're not gritty 😀
                  #347568
                  Howard Lewis
                    @howardlewis46836
                    Most of the time, I use a now elderly Lidl digital calliper. From time to time it goes haywire, but either removing the battery, or cleaning the scale with a clean cloth effects a cure. (Ditto for the vertical digital scale on the mill/drill, but is less easy, because of the risk of dropping, the bits and losing them. Removal is a bit of a fag, but is safer)
                    Battery life does not seem too short, and even with a failing battery (flashing readout) they still match the M & W digital calliper or an old fashioned micrometer.
                    Vernier or Dial callipers never drain their batteries, and only need the anvils cleaning!
