Nick,
Thanks for reminding me of the correct name for the standards. You see, it's been too darned cold & damp to do anything other than skulk in the house!!!
Anyway, what I actually did was to bring everything into the house and leave overnight so that they were all at the same temperature. Since we have storage heaters, the temperature is reasonably constant around 60 or so degrees F which is what the standards were marked as being correct at. As was the Rabone Chesterman rule. Everything was then checked as quickly as possible and the results recorded. Now ok it won't be up to laboratory standard, but at least it won't be at one or other unacceptable end of the temperature range.
I think I either placed then on something and relied on the jaw pressure to hold them or held them by the plastic bits in the nylon jaws of a small portable vice. Probably both as to measure 100, 125 & 150mm I used them in series. I also carefully wiped each measuring face before using them.
I've got to say that this experiment, as much as anything brought home to me the inherent inaccuracies of our measuring gear.
Peter G. Shaw
