ALDI 3D Balco printer
  • #381501
    Rik Shaw
      @rikshaw
      ALDI email tells me that one of this weeks online specials is this:
      I have no experience of 3D printers so any comments regarding this item would be appreciated. Hopefully one of these could be on its way down the chimney in a few weeks time . gift
      Rik
      Rik Shaw
        @rikshaw
        #381503
        Barnaby Wilde
          @barnabywilde70941
          That is a rebadged Wanhao i3Plus Duplicator & £300 is a competetive price for what it is.
          If you have no specific need for a printer & have the time to learn the basics & experiment then it might be a good buy.
          In the early days of computers I used to shout out loud to anyone who would listen that EVERY child should have one in the family. I feel exactly the same about 3D printers.
          Beware though, there isn't much of a market for good 3d printers with little use & if you find it's not for you then you may be chucking £250 away if you cannot offload it.
          #381506
          Mark Rand
            @markrand96270
            So, should one be getting one to make lost PLA patterns for foundry work? With the design being done via Alibre Atom, of course.
            #381508
              I think pattern would be the main use I would have for a printer if I get round to buying. I would only go for lost PLA if the part was shaped such that it could not be pulled from a sand mould.
              #381518
              Mark Rand
                @markrand96270
                Good point, and one that eventually crossed my mind later while out in the shed. Maybe next year.
                #381524
                Martin of Wick
                  @martinofwick
                  hmm, I have one (Wanhao) and in my view the mechanics are very poor and difficult to retrofix and the firmware not easy to upgrade without a great deal of faff.
                  That being said it turns out reasonable prints provided you are content to be constrained to 'not quite' engineering plastics.
                  Secondly, seems rather expensive, so unless you have a burning desire to unload 300 notes do a quick search for Creality Ender 3, should be sub 200 and possibly less (got mine for 160) from a UK supplier. Mechanics much better and upgradeable, but same problems with firmware upgrades. Your expectations need to be along the line of Chinese mini lathes, they will work reasonably well after you have spent some time fettling and retrofitting the junk components with ones that actually work.
                  If you only want a machine for pattern making then you wont need to print high temperature material like PC and POM so firmware changes not an issue. BTW, I have seen low temp wax filament becoming available if you wanted to use total loss moulding.
                  #381548
                  Rik Shaw
                    @rikshaw
                    I suppose I should have asked already but better late then never. How smelly – or not – are these things when they are running and is the noise – if any – likely to disturb at night as it would be operating in my study next to our bedroom.
                    Rik
                    #381554
                    Barnaby Wilde
                      @barnabywilde70941
                      Posted by Rik Shaw on 20/11/2018 16:55:37:
                      Rik
                      I've heard say that ABS can smell & is possibly bad for your health in a small poorly ventilated office.
                      I'm a heavy smoker & have an industrial sized carbon air freshener rigged up courtesy of our local cannabis farmer.
                      I'm happy to leave mine overnight but the noise can be as loud as the old dot matrix printers. Mine is also well isolated for vibration which was a bigger problem than noise or smell for us.
                      #381560
                        Posted by Martin of Wick on 20/11/2018 14:37:20:
                        The Aldio one has a heated bed which opens the door to PETG and Nylon 6 which certainly are 'engineering' plastics.
                        As far as I know the Creality doesn't have a heated bed.
                        (I had the chance of keeping the Dremel printer I reviewed for half price – I decided not to entirely because of the lack of a heated bed and inability to print other than PLA.)
                          Rik
                          Pla is almost smell-free, noise depends largely on not putting it on a 'drum like' surface. You can also slow down to reduce noise.
                          #381578
                          Martin of Wick
                            @martinofwick
                            I agree that heated bed is a minimum requirement for printing useful materials, Ender3 (and 2) have a heated bed. PETG Hmmm… = quite hard to print well and overly brittle – maybe there is a good variety or I need to persevere.
                            The problem (as with most budget printers) is the stock crummy hotends cant cope with the temperatures around 250 as the liner starts to distort and caused extruder flow problems (at least it did for me) Considering fitting all metal hotend replacement,
                            Delighted to be made aware by anyone in the know of a cheap (circa £300) 3d printer that will as supplied go reliably to 300c on the hotend and has a fully configured bootloader already installed so the firmware can be tweaked as required without the risk of bricking the mainboard.
                            #381587
                              I stand corrected.
                              I haven't had any issues printing PETG with my prusa i3 clone, and it is less brittle than PLA. Bog standard Mk 8 hot end.
                              #411427
                              Lainchy
                                @lainchy
                                I have the Ender 3, and it's superb. It has a heated bed, allegedly going to 100 degree's… after 230 minutes (exaggerated) and needs a certain amount of fettling to get it to work right. The Alloy beds are often warped, but this can be overcome with a sheet of glass/mirror. Hotend and extruder also are not without issues, but there is a huge community to help if needed.
                                For CAD I use Fusion 360 and I highly recommend this, and a chap on YouTube called Lars Christensen. It's a steep learning curve, but following his beginner series, it gives you the ability very quickly to understand how it works, and start modelling.
                                Michael Cox 1
                                  @michaelcox1
                                  I bought the Balco printer from Aldi before Christmas 2018. It worked straight out of the box and I have used it to make various workshop related items such as gears, vee beltpulleys, timing belt pulleys etc as well as some household items such as sonic tooth brush stand, camera lens cap, a small bin to fit the cupholder in the car, sat-nav holder etc.
                                  I find it a very useful addition to my collection of workshop tools.
                                  #411552
                                    Snap!
                                    #411556
                                    Rik Shaw
                                      @rikshaw
                                      I ended up buying one of these some months ago. I'd like to tell everyone how good it was but sadly the poor thing was dead on arrival – would not even power up. I had a full refund after taking the matter up with a very good technical support team who diagnosed a faulty PSU.
                                      Rik crying
                                      #411558
                                      jimmy b
                                        @jimmyb
                                        I got one a few weeks ago.
                                        Really pleased with it, done around 40+ prints, most over 3 hours and the only failure has been old filament.
                                        Jim
