alchin 1.5 scale traction engine HELP
Home Forums Traction engines alchin 1.5 scale traction engine HELP
  • #758950
    joseph tatler
      @josephtatler55359
      I am making the Alchin 1.5 scale using Hughes book.
      I am wondering if anyone can help by scanning or copying  the dimensions of the reversing link that is on sheet 6 of the drawings.
      the link dimensions in the book are not very clear as the fold is actually on the link diagram.
      I would extremely grateful if anyone can help.
      regards
      Joe
      noel shelley
        @noelshelley55608
        Sheet 6 in the book is of little help giving no meaningful dimensions, this is why you have to buy the drawings from Reeves. Chapter 18 , page 171 tells how to make it and the radius is 4.5″. I don’t have the drawings but someone here may have. Good Luck. Noel.
        #758956
        Phil P
          @philp
          If you send me a private message with your email address, I have a PDF which will give you the dimensions you need.
          Phil
          #758964
            It is all on sheet 8 pg 136-137 of the book and quite readable. Sheet 6 is just how it goes together.
            #759005
            noel shelley
              @noelshelley55608
              Joe, Jason is right ! It’s drawing 8 and though on the fold of the book I can read it which dimensions do you need ? Noel.
            Home Forums Traction engines Topics
