Aircraft General Discussion
Home Forums The Tea Room Aircraft General Discussion
Viewing 25 posts - 1,951 through 1,975 (of 2,013 total)
  • #649973
    Robert Atkinson 2
      @robertatkinson2
      As a change from the usual Spitfires practicing over the village I just had the dead sparrows Red Arrows go almost directly overhead at fairly low level while I was firing up the barbeque.
        Circlip
          @circlip
          At least you get a seat in this latest billionaires jaunt.
          Regards Ian.
          #651401
          martin perman 1
            @martinperman1
            I was sat outside this afternoon sorting a load of imperial spanners i got from freegle when I heard the sound of a Radial engine, i looked towards Old Warden to see the Lysander following a Shorts Skyvan very closely I assume for photography purposes, they went around a couple of times and then disappeared, after about ten minutes i heard a flock of Merlins heading towards me attached to the Lancaster, a friend told me that his village, Bromham, was expecting a Fly by of it, when I saw her pass over she was heading due east.
            Martin P
            #651406
            duncan webster 1
              @duncanwebster1
              When nasa wanted to piggy back the shuttle on a conventional plane they used a jumbo. I wonder why virgin has gone to the expense of making that twin fuselage affair. The only advantage I can see is that you'd need a crane to put the smaller craft on top of a jumbo, whereas with the virgin setup you can just jack it up.
              #651428
              Robert Atkinson 2
                @robertatkinson2
                A 747 does not go high enough. A 747 will get to around 43,000 ft while the Eve mothership goes to at least 50,000ft.
                Edit: To clarify further. The NASA 747 was just for transport between site. The Eve is basically the first stage of the launch system
                Robert.
                Edited By Robert Atkinson 2 on 09/07/2023 17:05:28
                #651457
                DrDave
                  @drdave
                  In addition to Robert’s points, two other things to take into account are:
                  It is a lot easier to drop a rocket than try to “throw” it off the top of the launch aircraft. The rocket drops like the proverbial stone. Have a look at a video of Orbital Science launching a Pegasus rocket from their Tristar.
                  The other point is a bit more esoteric. There are many videos showing how weapons dropped from an aircraft can fly back up and hit the aircraft, often inflicting serious damage. I suspect that falling free from a simple wing, as is the case for Virgin’s Mothership, is a lot cleaner than dropping from a conventional aeroplane, giving lower risk. A flight test to confirm safe release of stores from an aeroplane is part and parcel of weapon integration on an airframe.
                  Robert Atkinson 2
                    @robertatkinson2
                    Note that the Orbital Science Tristar, contrary to what is implied on a lot of websites and other media, was engineered in the UK. Marshalls of Cambridge designed and installed the modification. This included large changes to the pressure hull. This was a lot more complex than the Virgin Orbit modification that used the existing "spare" engine mount on the 747 Wing.
                    Robert.
                    #651513
                    DrDave
                      @drdave
                      The Tristar also needed significant reinforcement to the centre wing. All of the new parts were fitted inside the wing box and had to be able to fit through a manhole in the lower skin. That meant that for the spar cap reinforcement, for example, each length had to be split into three sections and spliced together on installation.
                      An aeroplane cabin is pressurised by bleeding air from the engines, reducing their thrust. To be able to reach the highest possible launch height, the OS Tristar was unpressurised, allowing all of the engine power to be used as thrust. The crew were provided with oxygen via masks as a result.
                      duncan webster 1
                        @duncanwebster1
                        Posted by DrDave on 09/07/2023 19:55:35:
                        It is a lot easier to drop a rocket than try to “throw” it off the top of the launch aircraft. The rocket drops like the proverbial stone. Have a look at a video of Orbital Science launching a Pegasus rocket from their Tristar….
                        Very good point.
                        #651553
                        Martin Kyte
                          @martinkyte99762
                          I guess the other point is that when NASA did launch from a 747 it was to prove that the shuttle could land unpowered so effectively it was carrying a glider. Top loading would give best airflow over the shuttle wings and with a combination of the thicker atmosphere and getting the airspeed right the shuttle would be effectively flying at the point of detachment. Probably a case of the Shuttle dropping the 747.
                          regards Martin
                          #651559
                          Robert Atkinson 2
                            @robertatkinson2
                            Posted by duncan webster on 10/07/2023 14:09:42:
                            Very good point.
                            Not always. See: https://www.youtube.com/watch?v=DbAKDJGykgY
                            Robert.
                            #651563
                            DrDave
                              @drdave
                              Posted by Robert Atkinson 2 on 10/07/2023 15:19:43:
                              Very good point.
                              Robert.
                              As I said in my second point. “There are many videos showing how weapons dropped from an aircraft can fly back up and hit the aircraft, often inflicting serious damage”
                              #651577
                              Robert Atkinson 2
                                @robertatkinson2
                                Indeed,
                                I was replying to Duncan with an example. I should have referenced you though.
                                Robert.
                                #652237
                                Robert Atkinson 2
                                  @robertatkinson2
                                  There has been a Catalina / PBY over the village recently. Got a couple of snaps today. Not great quality, overcast, raining and shot from a window. Canon M100 and EOS-M 55-200.
                                  #652241
                                  Ex contributor
                                    @mgnbuk
                                    Plane Sailing Catalina
                                    I have some pictures of that in a couple of locations at airshows.
                                    Nigel B.
                                    #652245
                                    martin perman 1
                                      @martinperman1
                                      According to a tracker fitted to the aircraft she is currently at Duxford, her base.
                                      Martin P
                                      #652251
                                      John MC
                                        @johnmc39344
                                        Turned back from RIAT because of thw weather?
                                        #655583
                                          Lee Rogers
                                            @leerogers95060
                                            Posted by Michael Gilligan on 08/08/2023 08:36:22:
                                            Electric ‘Air Taxi’… very brief demo
                                            https://www.bbc.co.uk/news/av/business-66266184?xtor=ES-208-%5B63343_NEWS_NLB_GET_Week32_Tuesday_08_August%5D-20230808-%5Bnewsbusiness_travel_air%5D
                                            Aviation history is chockablock with flying cars and personal transport for the everyman. They all fail and god help us if the muppets I see on the road ever take to the air. If Uber and minicab drivers take to the air it's hard hat and bunker time .
                                            #656167
                                            Jon Lawes
                                              @jonlawes51698
                                              For my day job I work as an engineer at a Charity that keeps vintage Royal Navy aircraft flying. We are currently in the process of scoping out the acquisition of a Gannet to add to the fleet. However before we do that we need engineers with experience of the Gannet aircraft to assist with assessing what will need to be done with the one we are hoping to acquire before it can be returned to the UK from its current base in the USA.
                                              If anyone has any Gannet experience that would be relevant they would really love to hear from you.
                                              Home
                                              Edited By Jon Lawes on 11/08/2023 21:06:05
                                              #656201
                                              Circlip
                                                @circlip
                                                Surprised that the recent 'Landing' on the motorway central reservation crash barrier didn't saw the fusegulge in half.
                                                Regards Ian.
                                                #656211
                                                Clive Hartland
                                                  @clivehartland94829
                                                  The Gannet was one of my favourite planes to see, good luck in your endeavours to resurrect this lovely aircraft.
                                                  #656212
                                                  Robert Atkinson 2
                                                    @robertatkinson2
                                                    Only work I ever did on a Gannett was a bit of cleaning and corrosion prevention on the one that was at the South Wales aircraft museum ( the one at Rhoose not the current one at St Athan) back in the mid 80's
                                                    Edit. The Gannett was XA459. She is now at Solway (Carlisle) and finally getting some attention. Funnily enough I also helped with Vulcan XJ823 at Carlise when I worked there in the early 80's
                                                    On the taxi flight, there was less coverage of the crash of a Vertical Aerospace prototype during a unmanned test flight at Kemble last week https://www.flightglobal.com/aerospace/vertical-faces-setback-after-vx4-prototype-crashes-during-flight-testing/154475.article
                                                    Edited By Robert Atkinson 2 on 12/08/2023 09:37:07
                                                    #656218
                                                    Lee Rogers
                                                      @leerogers95060
                                                      Posted by Circlip on 12/08/2023 08:12:27:
                                                      Regards Ian.
                                                      Info is a bit scant at this early stage. It seems that a very quick decision was made, neither carriageway was clear enough so it was straight down the middle . The pilot kept flying it all the way to a stop and power to his very cool elbow for that. The Fournier does stand quite high on its u/c so that's probably what saved it .
