Aircraft General Discussion
Home Forums The Tea Room Aircraft General Discussion
Viewing 25 posts - 1,726 through 1,750 (of 2,013 total)
  • #439728
    Meunier
      @meunier
      I had to check to see that Martin C did not correspond with Martin Baker
      DaveD
      and we occasionally get sonic bangs when the boys in blue from Mont-de-Marsan base get it just that bit wrong on low-level sorties..
      with many buildings around here roofed with Roman tiles, they do rattle a bit !
      Martin Connelly
        @martinconnelly55370
        I was near an RAF runway when the crew banged out of an F4 as it was landing, I was at Wideawake airfield when an F4 did a flight test after an engine change. We knew there was going to be a sonic bang.
        Martin C
        #439732
        Mike Poole
          @mikepoole82104
          Living next to Martin Bakers test facility at Chalgrove we hear quite a lot of test ejections from the Meteors they use for testing, I have not felt that they sounded like a sonic boom but I lived a few hundred meters from the ejection point the sonic booms were rather more distant and the culprits were possibly from the Clutch stations of Wildenrath, Brüggen, Gutersloh etc. Or maybe the Luftwaffe with their widowmaker Starfighters, who knows it was a long time ago.
          #439739
          martin perman 1
            @martinperman1
            A slight aside, I was sent to Martin Baker's site on the Isle of Man to service some machine tools many moons ago, I had never been before and when I walked out of the Airport building I got into a cab and said the Martin Baker Factory please, he drove 50yds and did a 180 deg turn and 50 yds again on the other side of the carriageway stopped and said there you are sir no charge. Silly me.
            Martin P
            #439746
              Heard my first sonic booms when Concorde first started – it used to go supersonic over the Bristol Channel, I was most disappointed when then made it wait until it was over open sea.
              Short Skyvan was among my favourite Airfix kits.
              Robert Atkinson 2
                @robertatkinson2
                Thrust SSC had a Martin Baker ejection seat rocket motor mounted "upside" down in the nose. The intention was that if the nose started to lift it would fire keeping it on the ground long enough for the hydraulic ride height control to jack the rear end up and generate aerodynamic downforce and drag. The test firing was pretty impressivebut diddn't sound like a sonic boom. The main seat "gun" cartridges might sound a bit like it though. I've worked on a Skyvan (a 3A) and several 330's and 360's It's no coincidence that Shorts were asked to build the Miles Aerovan a couple of years before staring work on the Skyvan. It's was more a case of what not to do rather than copying it.
                Robert G8RPI.
                #440103
                Martin Connelly
                  On the F4 as well as the initial main gun cartridge there is a second cartridge that is triggered after the seat has travelled half way out of the cockpit. The idea was to keep g forces below a dangerous level by not putting out the full force needed for ejection in one go.These two cartridges put enough pressure into the seat tube to push the seat and crew member out of the cockpit at a high G force so is not just a few psi. Once the seat has risen far enough the tube that is part of the aircraft and the seat part company and this pressure is released with a sound like a piece of artillery being fired. If you look at pictures of aircraft where the seat has been used you can see the tube protruding from the cockpit. The rocket only fired after the seat had left the cockpit.
                  Martin C
                  #447977
                    This is interesting [and I think legitimately falls within the thread title] : **LINK**
                    https://robotics.sciencemag.org/content/5/38/eaay1246
                    Download the full paper via that page.
                    Anonymous
                      Nipped out into the garden this afternoon to do a bit of digging between trying to sort out my mum's car with the garage and getting a quote to vulcanise tyres on my traction engine wheels. Not sure which was the most painful! I'd only been out a few minutes when a Spitfire flew over at less than a 1000ft on the way to Duxford. Certainly shifting, I hope he was below 250kts. Later model with pointy wingtips and the engine sounding like it had something loose, so a Griffon.
                      #457043
                      Jon Lawes
                        @jonlawes51698
                        My late grandfather always claimed he first heard a sonic boom in the 1940s. When pressed he would admit it was the blade tips of the Harvard.
                        #457046
                        martin perman 1
                          @martinperman1
                          I took a ride up the A1 to Newark Aircraft Museum on Wednesday, I'd never been there before and was most impressed with the exhibits, their theme seems to be late forties and fifties exhibits with a few sixties as well, I took 106 pictures so must have been good.
                          Martin P
                          #457057
                          Cornish Jack
                            @cornishjack
                            Witnessed 2 and a 'half' bang seat events when I was S&R instructing at Valley – all from Gnats. The 2 were 'Bloggs' and his instructor when the pitch control jammed. Their departure straightened up the trim and the Gnat continued circling on its own and descending slowly to end up close to a batch of holidaymaker swimmers … no one hurt!
                            The 'half' was the climax of a three ship formation take-off when No. 3 selected gear up too soon. He went back onto the runway sans gear and skidding on the slipper tanks. They caught fire and produced a travelling fireball about 20-30 yards behind him. He eventually came to a stop on the peri track just behind a queue of traffic waiting to cross the runway threshold. Bloggs was out and running just ahead of the fireball. Gnat bang seats were pneumatic in operation and after the fire had cooked the firing tube for a minute or so, the tube worked! Our resident Whirlwind had rushed to the spot to see if they could help and the departing seat missed their rotor by 'not a lot'!! We later heard that the head of the traffic queue was a a fuel bowser and,. seeing the Gnat plus fire ball heading towards him, he stripped every gear in the box trying to get moving!! Valley had its 'interesting' moments1
                            rgds
                            Bill
                            #457059
                            Mike Poole
                              @mikepoole82104
                              What is S&R Bill
                              Search and Rescue, just worked it outsmiley
                              Edited By Mike Poole on 13/03/2020 23:46:20
                              #457060
                              not done it yet
                                @notdoneityet
                                We were treated to a talk by Flight Lieutenant Charlie Brown BSc (RAFR) last night. He provided us with quite a lot of his experience re driving these old fighter aircraft. Seems like the spitfire was difficult on the ground but marvellous once airborne. I didn’t realise that so many ME109s were lost on either take off or landing (not under fire).
                                He also compared the spitfire to the ‘dolly’ as I think he called it. One can understand the reasons why the Hurricanes were sent to attack the bombers while the spitfires kept the german air cover busy!
                                Why ‘not exceeding 250kts’, Andrew? The griffon versions could easily go much faster than that?
                                #457071
                                Ron Laden
                                  @ronladen17547
                                  250 kts is the speed limit below 10,000 feet that's why.
                                  #457118
                                  Anonymous
                                    Ron is correct, with one minor bit of pedantry, the limit is below FL100, not quite the same as 10000ft. smile
                                    #461312
                                    David T
                                      @davidt96864
                                      Did I just see an RAF Globemaster go into Southend airport??
                                      Shortly followed by a second one
                                      Edited By David T on 31/03/2020 14:32:21
                                      #461348
                                      martin perman 1
                                        @martinperman1
                                        Posted by David T on 31/03/2020 14:09:35:
                                        Did they look like these **LINK**
                                        Martin P
                                        #461359
                                        Jon Lawes
                                          @jonlawes51698
                                          I wonder if thats the same Charlie Brown I knew from ETPS? I suspect there are many "Charlie" Browns! This one was primarily Rotary wing I think, he was CO at the time.
                                          #461361
                                          David T
                                            @davidt96864
                                            Posted by martin perman on 31/03/2020 17:25:31:
                                            Martin P
                                            Definitely a Globemaster, but it turns out it was doing touch-and-go’s, so I may have just seen the same one twice.
                                            #461411
                                            Steviegtr
                                              @steviegtr
                                              I thought this was appropriate. An old Tom Senior & Spitfire of a similar era. Well not quite.
                                              Steve.
                                              #463282
                                              Martin Connelly
                                                After about two weeks of silent skies there are aircraft out and about again. Here are two Eurofighters out this afternoon, about a mile away by the time I got the camera zoomed in on them.
                                                Martin C
                                                #463307
                                                martin perman 1
                                                  @martinperman1
                                                  I was outside looking at the hazy moon and spotted a couple of jet trails highlighted by the moon light heading NW.
                                                  Martin P
                                                  #464336
                                                  pgk pgk
                                                    @pgkpgk17461
                                                    I couldn't stop laughing at this article but probably wasn't funny at the time:
                                                    Pensioner ejects
                                                    pgk
                                                    #464340
                                                    Cornish Jack
                                                      @cornishjack
                                                      A little more plus comments … **LINK**
                                                      rgds
                                                      Bill
