Almost sounds like how a large diaphragm pump operates giving a puff of air out the outlet every few seconds and it is the same for my air brush pump just running faster , i will go and hook it up and see if it will blow chips around .
Maybe you could rig up something using a car windscreen wiper motor and hook up a con rod , piston and cylinder arrangement to the wiper arm on the motor ?
As there is no real pressure a piece of tube for the cylinder , delrin or nylon for a piston , o ring seal on the piston and rubber flap valves in the closed end of the cylinder .
![image.jpeg image.jpeg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
I took to a chunk of brass with a 3/8 drill and it did keep the area arond the drill chip free just using the air hose that connects to the air brush i then inserted some copper tube ( 1.5 to 2 mm ID
and it worked better . If you are machining a deep pocket it would struggle to blow the chips out of a pocket
Another option is modifying an old car air con pump and run it off a mains powered motor or possibly the compressor from a fridge .
Ian.
Edited By XD 351 on 12/01/2017 00:40:43
