I have a 6kW ground source heat pump – installed 2010.
The house, a converted threshing barn, was designed with a heat pump in mind.
The walls are basically 18” stone, 2” gap, 8” closed cell insulation, 1”gap (to facilitate wiring) and plasterboard, with double or triple glazed windows according to size.
A warm roof is fitted with insulation similar to the walls.
The downstairs floor is insulated.
Underfloor heating is fitted, both upstairs and down, with stone flooring downstairs and low tog carpets upstairs.
The ground source is 2 off 200 metre U shaped loops laid at least 2 metres deep in the field in front of the house. The field conveniently slopes down away from the house so the pipes were laid in sand with a constant gradient so as not to allow any air traps to occur.
The heat pump is installed in an outhouse so noise is not a problem.
The heat pump works on a 3 degree differential and the lowest temperature in the output pipe is about 4 degrees C in winter, so there is not any significant surface cooling due to the heat pump.
The heat pump works very well, but is usually only used to produce hot water (52 degrees) as the house is usually heated using a 6kW wood burning stove (as I have a near inexhaustible supply of hardwood logs).
The heat pump soft start module failed during Covid and it took about 8 months to acquire an (upgraded) replacement which, when fitted showed the compressor had failed and killed the soft start module, which explained why the module had been upgraded.
The local heat pump installers said they only installed and did not repair. They did, however, point me to a local firm who maintain commercial refrigerators who had a suitable unit in stock and soon fitted it.
So, for any heat pump compressor failure look to commercial fridge repairers to get a replacement compressor.
Paul
