As we moved in May 2020, and in September replaced the oil system with ASHP, I can’t compare the running costs or performance, all I can say is how we find the ASHP. The reasons for replacement were that the water tank was on its last legs & boiler was rather old, the most important reason was the oil tank was in the way of the planned workshop! Other reason for ASHP, was there is no gas in the village.
We live in a bungalow, built in about 1960, with solid floors, probably no insulation in the floor, cavity walls, with insulation, loft insulation & double glazing, probably not the ideal house for an ASHP. When fitted, a few radiators needed changing to either slightly larger ones or double radiators instead of single ones. We have had no issues with the system heat wise, it runs 24×7 as both of us work from home. The system is very quiet, outside you can hear the unit if you are next to it, go round the corner & can’t hear it at all. At the time we had the ASHP installed, the scheme was we paid for it, but over the next 9 years we get several payments a year, totalling about £9000, not covering all the original outlay, but better than nothing.
We have had issues, that was a pump & the room thermostat, both which could cause an issue on a gas/oil system.
Overall we have been happy with our choice & don’t have to worry about when we need to order oil, plus reducing our use of gas with it’s volatile prices.
We have also had solar panels fitted for a few years now, facing a mix of east & south, so again, not ideal, but that is the way the roofs face where it made sense to fit panels. The panels do help significantly from March to November, lowering our usage, by about 40-50%, plus exporting a reasonable amount, although the export was not enough to pay for the installation on their own.
Mark.
