Hi all, relatively ignorant on construction of miniature I/C engines, but was just wondering, i've seen all the photos, videos and posts about turning cooling fins on cylinder barrels of air-cooled engines and wondered if there was an easier way. As an example, the air conditioning industry uses pressed corrugated aluminium fins which are a tight fit over copper tube for nearly all heat exchangers, whether it be a condenser, cooling coil or heating coil. Similarly car radiators are nearly always pressed metal fins slid over the tubes containing the fluid to be cooled. I realise that I/C engine cylinders run a lot hotter, but has this construction method been tried for cylinder barrels and if so what were the results?
