AERO ENGINES
AERO ENGINES
Home Forums Workshop Techniques AERO ENGINES
  • This topic has 6 replies, 5 voices, and was last updated 7 July 2019 at 17:42 by PIERRE COURBOULEIX.
  • #417637
    PIERRE COURBOULEIX
      @pierrecourbouleix60628
      Hi,
      I'd like to make a small internal combustion engine but my problem is how to machine the crankshaft ?
      I have a small lathe from Warco and a small milling machine from the same supplier.
      I already made steam engines and a small steam loco in 45 mm.
      Thank you for your advices.
      Pierre
      PIERRE COURBOULEIX
        HOW TO MACHINE A SMALL CRANKSHAFT
        #417646
        Thor 🇳🇴
          @thor
          Hi Pierre,
          Could this link be of any help?
          Thor
          #417669
          Hopper
            @hopper
            Get yourself a copy of this book LINK
            #417670
              Step by step with pictures part way down this thread of mine and also this one
              Edited By JasonB on 07/07/2019 06:59:11
              #417672
              Ron Laden
                @ronladen17547
                Posted by JasonB on 07/07/2019 06:56:17:
                Excellent Jason, with the step by step pictures and the how to do text it couldnt be better, I always learn something from your build threads even though I,m not making that item.
                Ron
                Edited By Ron Laden on 07/07/2019 08:35:18
                #417777
                PIERRE COURBOULEIX
                  To Thor,Hopper, Jason and Ron,
                  I thank you all the fellows who respond to my querry ( I'm a bit lazy to answer to each of you, the temperature is nearly 39 ° C outside ………&hellip.
                  Now lets strart to make a crankshaft from the solid. I tthink it is a similar procedure ( work instruction) for a twin cylinder ?
                  I 'll post the results of the "disaster" I can produce ! (just a joke).
                  Cheers…
                  Pierre
