I might need to put a new fitting in a plastic cover which caps off a modern car petrol tank. Can/should I use brass with a Viton seal or would stainless or some sort of engineering plastic or different seal material be better?
A new pump is around £300, there isn't anything wrong with this one, just the fool who was swinging on it and snapped off the original hosetail which is part of the one piece injection moulded part![blush blush](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Edited By Russ B on 13/07/2015 14:51:15
