Hi All,
I’ve only just joined the forum so hi, and I hope that someone can offer me some advice about where to make a start in model engineering.
Some background:
– I consider myself fairly ‘handy’ and currently build and fly R/C model aircraft. I therefore own and run a number of 2-stroke glow motors.
– I have just signed up for an evening class, at a local college, in model engineering, that gives me access to lathes, vertical milling machines, etc.
– I would ideally like to build a glow motor of my own, and the teacher of the course seems to think that this is well within my capabilities.
– It has been many years, but I used a lathe, etc. at school, and in evening classes when I was a teenager.
Having read a little around the subject on the internet, I think my first project should be as simple as possible – but I would still like it to be practical i.e. something that I can build a ‘ plane around later.
I would like to avoid using castings (any beginners errors could prove very costly
So, it boils down to choosing a barstock engine plan to download or buy.
I’ve come across the following link to the LME125 – “Puck”:
Which looks ideal. I found info that it uses an off-the-shelf OS R/C carb – so saves me having to try to make that at this stage. Does anyone have any further info about this engine, or has made it. It uses some other parts from suppliers (e.g. bearings), does anyone know if there are viable alternatives available in the UK (it’s a US design)?
Alternatively, there are a few sets of plans available from MyHobbyStore. The
Any help or advice about these (or any alternative designs) will be very gratefully received.
Sorry about the length of this (my first post), and thanks if you’ve read this far!
Don.
