Posted by Stuart Munro 1 on 16/04/2021 06:52:13:
I can see and agree with the aim of a single category discussion such as this, yet also agree with those (I was one of them) who sought to define the edges of the 'Chinese family mini-lathe' by exploring the options around that are in many ways similar, yet still different. Indeed this must be of great help to those considering the purchase of a mini-lathe.
Stuart
I sympathise because I started without a clear idea of what I wanted a lathe for!
As an ex-software engineer I'm trained to insist on Formal Requirements rather than go with whatever solutions the customer offers. Most users tune into stuff they like they look of rather than do a hard-work analysis of actual need! The ignorance is bliss approach works well with consumer items like teapots, shoes, and motor cars, but failing to define requirements fails as soon as the answer has to address any kind of speciality. Machine tools are a case in point.
Best to define what the lathe is for before choosing one if you can. Much easier to advise when a newcomer asks:
- I want to make clocks; what sort of lathe should I buy? Or,
- I want to repair traction engines, what sort of lathe do I need?
Knowing the requirement is only the start. It sets a baseline against which compromises will be made. Nasty constraints like money, space, availability, and domestic authority!
Not knowing a newcomers limitations or purpose makes it hard to answer Sherline vs Mini-lathe type questions in isolation. If the questioner works on model railways under the stairs, a Sherline is a good bet, but it isn't a motor-bike mending bruiser! And maybe Sherline isn't good enough either, a Cowells is needed.
Best general lathe advice is to get the biggest you can afford: it's because big machines can tackle large work whilst still being able to do small stuff. But small work on a big lathe isn't comfortable, which is why some own more than one.
A mini-lathe is the biggest machine I consider sensible in a domestic setting: they'll sit on a dining table or spare bedroom and are fairly quiet unless the job chatters. But a big mini-lathe makes far more mess than a Sherline, and a weakling like me wouldn't want to lift one on my own. (No problem for two weaklings!) Ideally a mini-lathe goes in a dedicated workshop, and anything bigger definitely should. And the workshop should be dry and comfortable with adequate power and good lighting, plus a workbench, vice and all the rest. The budget has to tackle that too, maybe over several years.
Practically, the Mini-lathe, next size up Far-Eastern, Myfords and similar are all about the right size and capability for a small dedicated workshop doing mid-range work.
There are always exceptions. If a newcomer doesn't quite know what the lathe is for, I suggest the answer is to buy general purpose and experiment. With hindsight I dithered too long before buying a mini-lathe and getting stuck in. Using one taught me far more than reading about them; I found many books and opinions only made sense after using one in anger. The mini-lathe is a good "don't know what I want" learner machine: not too small and has screw-cutting and the other basics. Availability and relatively low cost new are big advantages for a beginner. Doesn't mean mini-lathes are perfect. Far from it. Although they do the job, they are quite rough, likely to annoy chaps brought up on smooth professional gear.
To me buying the best you can afford and making it last a life-time is an out-moded idea. Dates to a time when there was a sharp divide between good and bad tools. Not so today: we are surrounded by medium grade tools, fairly decent, but not intended to last. Made to be used and replaced, not cherished. So, I bought a mini-lathe fully expecting to replace it. 3 years later I changed up because it was too small, not because it was junk. At the time, it was convenient to buy the biggest Chinese lathe that could be squeezed into my workshop with a milling machine. Buying new eliminated all the bother and risk associated with second-hand, which back then I didn't have time for. I got a WM280 fully expecting to replace it later with an ex-industrial machine, but in practice it does all I need, and I haven't bothered.
Not many of these considerations involve make or country of origin! To my mind it's a mistake to eliminate technical options based on secondary considerations like brand too soon. Though reasonable for hobbyists to spend their money as they want, at least try to recognise the difference between logic and emotion. Although supposed to be cold evidence based thinkers, several studies have shown purchasing decisions made by grizzled engineers are positively influenced by scantily clad young ladies draped over the equipment. This is true even after the fools have loudly denounced the girlies as an obvious attempt to influence them! We are all human. The important thing is to enjoy the hobby.
Edited By SillyOldDuffer on 16/04/2021 11:45:22
