Advice and opinions required
Home Forums Beginners questions Advice and opinions required
  • #708765
    teucher
      @teucher
      Hi there, i was looking for some advice regarding a lathe purchase. Warco have 24% off sale on the wm250 v lathe , i was original going to purchase the wm180 but with this sale price im tempted to buy the wm250. However this is stretching my budget and i know i will need additional tooling etc. What your opinion on these lathes and what tooling etc would you advise i but first, also would a DRO  kit be high on the list. Any advice and input would be very much appreciated as i want to start off on the right foot.
      Thanks
      Journeyman
        @journeyman
        The WM250 is a good lathe but I am biased as I have had mine without problems for many years (see Journeyman’s Workshop ). The newer WM250V should be even better as it has a 3-phase motor with VFD for improved speed/power control over the older model with DC motor.
        The Warco comes with the major accessories 3-jaw and 4-jaw chucks, face plate and steadies so other than a couple of toolbits and a tailstock chuck you shouldn’t need much in the way of spares to get you going. The DRO is nice but possibly a good idea to learn to use the lathe without and it can be added later.
        Size wise, to a certain extent bigger is better and the WM180 is basically a beefed up mini-lathe. If the budget stretches I would go for the WM250V.
        Clive Brown 1
          @clivebrown1
          The WM180 appears to be out of stock. as is the WM250V. The WM250 variable is the one on offer. Not the same drive system. Like John, I wouldn’t be bothered about a DRO. At 300mm the WM180 is quite short between centres, I would find that a nuisance.
          #708778
          teucher
            @teucher
            Hi there,  yep i just checked again it is the wm250, i did think the wm180 was on the small side but would have done the job i think but now im thinking the wm250 has more to offer for the future maybe.
            #708794
            Robin
              @robin
              You have to be quick on that Warco sale because they keep changing what’s on offer. I bought their universal cutter grinder because it was on my shopping list and I didn’t reckon I would ever see it 24% off again. Now I need to find a universe in need of a trim 🙂
              Robin
              #708799
              teucher
                @teucher
                Yeah i was thinking that myself, i am tempted to buy it this weekend as the offer may change on monday . I checked the website and the shop i closed until monday. The web site has buy it now option.
                #708833
                Journeyman
                  @journeyman
                  Do please note that the lathe on offer is the WM250 and not the WM250V. Your opening post mislead me a bit there I’m afraid as you said ‘WM 250 v’.  It is also a bit misleading of Warco to add the ‘variable’ bit to the website. The offered lathe is the older model with DC drive system. Caveat Emptor applies.
                  Bo’sun
                    @bosun58570
                    After the usual fettling, the WM250 works well for me.  However, I wish I’d splashed the extra dosh and bought the WM250V for the extra benefits of VFD and power cross feed.
                    I’ve seen many complaints about the gib adjusting screws on the cross slide interfering with a permanently fitted saddle clamp lever.  Simply replace the socket head cap screws with minimum length socket set screws (grub screws).
                    Many of the mods and improvements that can be found for other small Chinese lathes, equally apply to the WM250.
                    Happy turning.
                    #708848
                    Anonymous
                      I won’t comment on the lathe choice as I have never used a far eastern lathe. But for accessories a DRO wouldn’t even be on my list. I have a professional 2-axis DRO on the vertical mill, and it is the single most useful item I have ever bought. But on my lathe I have never missed a DRO and will not be fitting one. Personally I wouldn’t bother with a quick change toolpost either. Again I’ve never felt the need for one, I just use the standard 4-way toolpost.
                      #708887
                      ChrisLH
                        @chrislh
                        Opinions definitely vary ! I expect what you are making has a large influence on what you find valuable.
                        Unlike Andrew I wouldn’t be without a DRO on the lathe longitudinal slide, invaluable for parts where axial dimensions are critical. Haven’t bothered on the cross slide though as friction setting dial and mike do all that I need.
                        Again unlike Andrew life was changed for me with the acquisition of a quick change toolpost. I just hate fiddling about with packing every time I change a tool. Also if you need to make numbers of identical parts the ability to swap tools without resetting zeros every time is invaluable (noting that Andrew does this with his 4 way toolpost).
                        Finally as time goes on lifting heavy items into awkward places (like swapping chucks on the lathe) becomes more of a problem. Something to bear in mind if you are getting on a bit.
                        #708925
                        teucher
                          @teucher
                          Thanks for the info guys, i have a few things to think about now. The warco sale is for the wm250 with dc motor, the wm250 v however has AC motor and motorised cross fed. Without the sale there is only £100 diffrence between them but the wm250v seems the better machine but out of stock at present and approx £500 more expensive as its not in the sale. My dilema now is, i could buy the sale model and use the money saved for a stand and tooling , or just wait and save a bit more for the wm250v. Im no real hurry as im still setting up the workshop. Its really down to needs and wants i think. If only cash was no issue haha.
                          #708986
                          Pete
                            @pete41194
                            If I were to use my own experience as a guide line. I’d suggest buying the largest and best optioned machine tool you can will save far more than working up in size with more and better options later such as the power cross feed etc. as I did. And without question, the extra cost would be quickly forgotten by most. And anything with a VFD and a 3 ph motor will be far superior than some of the failure prone electronics used for most of the single ph. variable speed machines. Although even those have improved at least a bit over what they once were. But with that 3 ph and VFD, your also not locked into specialized electronic components that may or may not even have replacements available at some point. I have a variable speed single ph lathe and a VFD 3 ph on my mill. And can say with certainty the mill operates much smoother, quieter and with far better optional parameters for motor control I have available with the VFD.
                            Any lathe above a 6″ /150 mm capable part diameter or below 12″/300 mm, the extra tooling should be quite close to the same average cost. And those extras and mostly from the variety of cutting tools required will over some time probably end up being close to what the lathe itself cost. Maybe not for a fully rebuilt back to new specifications such as a Schaublin or something like a new Weiler lathe. But for what most of us could afford to buy, what all the extra tooling costs would still be fairly close for most. It still depends on what your doing as far as just how much that extra it might be. Buying cutting tools at the cheapest possible price will almost always be a waste of money as well.
                            I’d also budget for a half decent bench grinder and immediately replace whatever grinding wheels come with it since none of them being sold today are best suited for grinding high speed steel. A dealer specializing in catering to wood working hobbyists would probably be the easiest place to find for the correct advise about which wheel grit and hardness to buy. And teaching yourself to properly grind and then hone your own HSS cutting tools isn’t imo optional since even with today’s vast array of different replaceable tip cutting tools, they still can’t do everything.
                            While there’s been large advances in the last 100 years and especially so with our commonly available cutting tool technology. Manual lathe work and the methods or techniques are pretty much exactly the same today. One of the best books I’ve found online would be this one, http://www.opensourcemachinetools.org/archive-manuals/Hercus_TextBook_of_Turning.pdf
                            Tee publishing is an excellent source of more specific and detailed tool information than any forum thread can go into. https://www.teepublishing.co.uk/books/in-your-workshop/ and some of the Workshop Practice books they stock are very good. Work holding, screw cutting, milling in the lathe and tool sharpening would be my first picks.
                            For those with maybe less experience, there’s lots of available information about how to do almost any task on a lathe on forums like this. But it seems not a whole lot about a few basics that seldom seem to be stressed enough for just general and more entry level advice. And I wish I’d known about them a long time ago because it cost me a fair amount to instead to learn the hard way.
                            Always double check you will have enough clearance for the carriage, top and cross slides for whatever full distance they have to travel before you engage those power feeds. It’s all too easy to run those into a spinning chuck or other part of the work piece or lathe. You will do it at least once because everyone does, but I did mention it.
                            Even lower cost off shore machine tools have fairly high precision parts fit and critical alignments. Anything you can do to help preserve whatever accuracy they came with will help. So keeping your ways and sliding surfaces as clean and properly lubricated as you can will help. If your oil is at all discolored after using the machine for any length of time, it means your not oiling often and / or not using enough each time. That oil both lubricates and helps flush out any contamination and the inevitable wear particles just from using it. And a good way oil and other lubrication where it’s needed is the cheapest preventative maintenance you can do. Trying to polish or use abrasive grit paper on your parts to improve there surface finish can also be very harmful. Any abrasive particles coming loose land on your oil coated way surfaces and will then act just like a lap. I always protect the lathe bed, lead screw or any other exposed slide surfaces by wrapping them with cheap aluminum kitchen cooking foil first. I try to do the same as best I can while turning any hot rolled steel, cast iron castings as well since the hard outside skin is pretty abrasive until it’s removed. Turning rusty steel is also harmful. Most don’t seem to understand that rust is in reality a poor but still rudimentary form of carbide that at a macro level is much harder than the material it was created from. Wire brushing most of it off first as well as using oil over the remaining to stop any dust from floating where it shouldn’t can help. I also use a piece of plywood across the lathe ways anytime I’m removing or replacing a chuck. It’s not if you’ll ever drop a chuck on those ways, only how long until you do.
                            Both the head and tail stocks morse tapers are also or should be ground to high precision for size, taper and surface quality and so are extremely important surfaces to maintain. Morse tapers hold by a combination of a wedging action and because of there very close matching parts fit, a high amount of frictional grip between each of the mating parts. Both require almost surgical cleanliness to preserve that level of accuracy. Any tapers that are rusty, damaged or previously scored should never be used. Trying to repair those female morse tapers isn’t easy or cheap. Places like Ebay have loads of scored or seriously rusted MT tool shanks that wouldn’t be worth having if they were free unless you have the precision grinding equipment to restore them. Spinning a MT tool in a taper even once will generally score the usually unhardened female tapers these lower priced lathes have. And once that happens, there frictional grip and the tapers accuracy is vastly reduced on any tool used in the future even if it has an unmarked taper.
                            Lathe chucks also require a disassembly and through cleaning from time to time depending on how much there being used and what your doing. Through drilling or boring of parts helps load the chuck even more with chip contamination. So that cleaning and re-lubrication is just required maintenance once they start to feel gritty. Any high use threaded or moving item on a machine tool also requires at least semi random cleaning and re-lubrication. Slide, carriage, tail stock locks etc.
                            I’d suggest that for one off parts, a dro isn’t an absolute way to guarantee any parts will come out to your exact target dimension. Any glass or magnetic dro scales today would be far more precise than the machine tool there being used on. The reason for that is variable and unpredictable amounts of deflection happening throughout the whole lathe depending on the material hardness being cut, feed rate, depth of cut and the inevitable and variable loads they generate throughout the whole lathe. So there’s still a fair amount of double checking for the parts actual measurement involved. With multiple parts of the same dimensions, a dro would help a lot of course. They also eliminate compensating or allowing for feed screw backlash and counting full or partial amounts of hand wheel turns. But real machinists were making very high accuracy parts long before dro’s were invented. Yes there a nice to have accessory, but there’s many other items I’d be buying first.
                            #709201
                            teucher
                              @teucher
                              Thanks for the sound advice, i think i may save a bit longer to get a better lathe or look around for a good second hand machine with higher spec. I only want to buy once. I would prefer a new machine so i dont buy something with hidden problems.
                              #709287
                                That Hercus book is a little gem, Pete !!
                                I’ve never seen it before … Thanks for the link.
                                Mick B1
                                  @mickb1
                                  I’m pretty happy wth my WM250V, now 9 years old, in regular use and performing well. I use a Myford double-swivel vertical slide for milling – limited capacity but has done everything I wanted so far. Powered cross feed is so very useful in milling that I really wouldn’t want to be without it, and I’d suggest waiting till WM250Vs come back into stock, or place on backorder if Warco do that.
                                  Concentricity on the 3-jaw supplied is so good that I’ve only ever used to 4-jaw when there are funny shapes or eccentrics to do.
                                  Changing chucks is a pain, too – IMO the worst feature of these machines.
                                  The lathe can turn parallel within less than 0,01mm over 100mm length. All the basic features and characteristics are sound and I’ve had no electrical issues of any kind.
                                  You can bend the saddle drive pinion shank if you power feed into a dead stop, or the end of cross or saddle travel – but I’ve found you can straighten it again with an ordinary crowbar.
                                  #709378
                                  Ex contributor
                                    @mgnbuk
                                    Warco have a used WM280V on the stand with all the original equipment & a coolant system for £1800 + delivery at the momemt here.
                                    This appears to be a very good saving on the new price & may appeal to your budget ?
                                    Nigel B.
                                    #709445
                                    Diogenes
                                      @diogenes
                                      Bed width envy.
                                      #709497
                                      teucher
                                        @teucher
                                        I just checked it out, would be a better lathe long term than say a wm180. I am tempted but its a fair size and very heavy. I may struggle to fit it in my limited workshop. But at that price it seems a good deal.
                                        #710089
                                        Pete
                                          @pete41194
                                          Yes I think so as well Michael. Many recommend the South Bend How to Run a Lathe book (HTRAL) for the more general and basic entry level information. And while it’s certainly worth having, imo I think the Hercus book is what the HTRAL should have been. But it just doesn’t quite hit the same level of more in depth detail.
