Hmm….
I urge caution using ONLY VFD for setting drilling speeds. Unless you have a fancy VFD with vector control, I find power drops off quite sharply below about 1/3 plated motor speed. So when you need the power for that large hole in some cast steel, 'taint there unless you have selected a decent ratio on the pulleys. And, if you are trying to extract torque in any quantity for a long period at low RPM, your motor will be sucking up a bunch of amps and getting toasty warm – best stop when you sense the acrid fumes!
On a lot of the older 'workshop' brit drilling machines, rated say at 3/4 or 1 inch capacity, it has always struck me that the lowest speed, seems scarily high, typically 400 to 600 RPM (it may be because I am wary of the nasty bite a drill is capable of if not careful). For example, my the lowest belt speed is 450 RPM which is deemed OK for 1" HSS drill speed for industrial Gradgrinds to suck their pound of flesh (quite literally I suspect) from man and machine.
BUT, I wouldn't want to attempt hole opening to 1" at that speed with a manually held vice however, using the VFD to give what for me would be a comfortable speed of 150 RPM, I could stall the motor. So ended up clamping down and doing the job in the safe way at about 300 RPM.
Neither, out of sheer laziness, would I rely on setting the mechanical speed at 2000 RPM and just use the VFD to turn it down to an appropriate workpiece speed for the same reason. Always best to change belt position if you can.
For the average run of hole drilling from 1/8 to 1/2, I am quite happy to plod along at timorous speeds between 400 and 600 RPM more or less irrespective of material and would go much lower if |I could for larger holes.
I did explore the possibility fitting a 6 pole motor to reduce the available speeds on the Denford by about 1/3, although only 550w, it was a bit of a monster compared the original and considerable work to adapt, so it gathers dust for now.
Edited By Martin of Wick on 01/04/2021 16:15:07
