Posted by Dave Halford on 14/04/2023 12:22:03:
Steve,
You have three separate problems in reality.
1 you are starting to go around the circle again
2 spindle speed
3 table feed speed
2 can be fixed with the 12" countershaft pulley solution from page 2 that you suggested and from Jasons post gives you 80, 250, 750 spindle speeds that you seem to have rejected for some reason. 90 is fine for slitting saws on my Centec 2A. Keep the smaller pulley and belt in the drawer for when you want to use end mills ( assuming you can find /make a B&S taper cutter holder.)
3 is based on feed speeds for a 12 tooth cutter. Buy cutters that have a tooth count matching the machine.
Hi Dave
It is true that I’m going around in circles again to some extent
The reason for rejecting the pulley based solution was that it didn’t work quite as Jason anticipated. A 12” pulley would give around 250 rpm at the countershaft 119, 244, 325 at the spindle, given the ratios of the existing pulley. I actually need around 150 at the countershaft, which would give 71, 146, 195 at the spindle.
This means I need a motor that runs at about 450rpm, to get 150 at the countershaft- which is too low for VFDs without losing significant power, in theory anyway.
Now, I could go for a motor which runs at 750 rpm AND a bigger countershaft input pulley. That might be the way to do it, and by changing countershaft pulley, I’d have access to higher speeds if I need them.
Steve
