Adjusting PCL Mk3 tyre inflator
Home Forums General Questions Adjusting PCL Mk3 tyre inflator
  • #400551
    Grindstone Cowboy
      @grindstonecowboy
      Hi
      Does anyone have any experience on adjusting / calibrating a PCL Mk3 tyre inflator? I've had it about thirty years, and always regarded it as being more accurate than any other gauges I own, but recently noticed that, compared with three other gauges I tried (which all agreed to within 1 lb/sq in), it's reading about 5 too high – an indicated 40 is about 35 by the other three. The others are a very old Dunlop slidey piston type, a dial gauge I picked up in the USA, and a cheapish digital one. If they all disagreed, I'd still believe the PCL, but they don't.
      I know you can't really rely on anything to stay calibrated too long, but is there an easily accessible adjustment screw or something that I could tweak to get it a bit closer to my perceived reality?
      Thanks,
      Rob
      Grindstone Cowboy
        @grindstonecowboy
        Query on how to calibrate a PCL Mk3 tyre inflator
        #401171
        Grindstone Cowboy
          @grindstonecowboy
          Just to close this thread off, and in case anyone needs similar information, this is the reply I received from PCL:-
          "Sorry the MK3 cannot be adjusted or recalibrated.
          The gauge should be oiled, this will prevent the gauge from sticking, which can give incorrect readings.
          It should be oiled a few times a month depending on usage. The oil screw is located above the serial number."
          Well, mine has never been oiled since I bought it, so hopefully this will help.
          Rob
