Adhesive for foam insulation
Home Forums Workshop Techniques Adhesive for foam insulation
  • #524524
    Nick Clarke 3
      @nickclarke3
      I am setting about insulating the metal up and over door to my garage/workshop
      I have some 25mm foam insulation sheet, not the foil covered type, and intend sticking it to the inside of the door.
      What do you suggest will be the most successful as anything with a solvent is likely to attach the foam – perhaps high viscosity PVA like NoMoreNails or Silicon sealant/adhesive?
      Nick Clarke 3
        @nickclarke3
        #524525
        Ady1
          @ady1
          pinkgrip
          #524530
          Nick Clarke 3
            @nickclarke3
            Posted by Ady1 on 03/02/2021 14:32:26:
            pinkgrip
            Isn't that solvent based though and likely to attack the foam?
            #524532
            Clive Brown 1
              @clivebrown1
              I've used contact adhesive for foam backed vinyl. An aerosol spray-can is very easy and convenient for applying adhesive onto the foam and the normal liquid adhesive applied to the solid surface.
              #524534
              Tony Pratt 1
                @tonypratt1
                Contact adhesive or non solvent 'grab' adhesive. Dead light so nothing fancy needed.
                Tony
                #524536
                  Everbuild do one called "Dry Fix FR" made for sticking insulation to walls etc.
                  #524584
                  Bazyle
                    @bazyle
                    "foam insulation sheet" is a bit too vague. One such might be expanded polystyrene which is going to be rather different in its susceptibility compared to polyurothane or some other types.
                    Edited By Bazyle on 03/02/2021 17:45:47
                    #524625
                    Nick Clarke 3
                      @nickclarke3
                      Posted by Bazyle on 03/02/2021 17:44:56:
                      It is expanded polystyrene – this stuff **LINK**
                      Thanks Nick
                      #524637
                      Bazyle
                        @bazyle
                        I think there is a special 'foam in a can' for eps specifically. Have a look at all the ones available on teh Screwfix website.
                        #524639
                        Fowlers Fury
                          @fowlersfury
                          Nick, not sure I'd want to use expanded polystyrene in a garage/workshop location even when the EPS contains fire retardant. Have you had a look at Kay Metzeler's safety data sheet?
                          Some points therein:
                          • Extreme caution must be exercised when storing, shaping and applying EPS to ensure total protection from flame and/or fire.
                          • EPS should be kept away from all substances of unknown composition that could contain solvents e.g. paints or adhesive.
                          • Avoid all sources of ignition: sparks, open flame.
                          • Incompatible materials: Solvents e.g. paints or adhesive / Creosote / Diesel / Heating oil / Petrol / Paint thinners / White spirit
                          Some years ago, I went for this product to insulate the inside of steel garage doors:- https://www.weatherstop.co.uk/collections/garage-door-insulation
                          Very effective, it seems to be polyethylene "bubble sheet" inside a double layer of aluminium foil.
                          #524642
                          Peter Jones 20
                            @peterjones20
                            As with everything nowadays, there is far more to learn than you ever wanted .
                            Interesting topic though.
                            I'm going to use paintable expanding foam in a can to cut down the rattling from belt cover on mill/drill
                            #524650
                            Bazyle
                              @bazyle
                              this might work but I've not used it myself
                              #524658
                                Posted by Bazyle on 03/02/2021 22:06:56:
                                I think there is a special 'foam in a can' for eps specifically. Have a look at all the ones available on the Screwfix website.
                                That's the one I mentioned earlier works with PU and EPS boards etc. details
                                Edited By JasonB on 04/02/2021 07:06:25
                                #524671
                                David George 1
                                  @davidgeorge1
                                  Have you bought the insulation yet as the weight of thick insulation may make the door very heavy and the spring actuator may not work. I did something similar and found thicker insulation very wealdy to fasten to the door and too heavy. I bought some 12mm foil backed insulation and found that it slides into the framework supports on the inside of the door and other than a few bits of foil tape no adhesive used. The insulation value is more than adequate and the worksop is loads warmer and I can open the door!
                                  David
                                  #524672
                                  An Other
                                    @another21905
                                    I did this to the inside of my garage door years ago – I used to condensation on the inside (steel door), and I had some spare 25mm foam, so I just stuck it to the inside of the door using the spray on foam builders adhesive mentioned above by Jason – works fine.
                                    #524687
                                    Tony Pratt 1
                                      @tonypratt1
                                      I used 25 mm thick foam on the garage door & it worked fine but you have to watch the weight & adjust the springs to compensate.
                                      Tony
                                      #524723
                                      Dave Halford
                                        @davehalford22513
                                        You can simply test EPF for fire yourself, break a bit off and try to burn it, take the flame away and it should go out.
                                        #525239
                                        Ex contributor
                                          @mgnbuk
                                          Aldi locally (Huddersfield) currently have this insulation wrap on offer, which is quite lightweight & inexpensive (£9 for 4.5 square meters). A couple of rolls found their way into my trolley yesterday, so I'll see how effective the stuff is on steel up-and-over garage doors in due course.
                                          I'll use PU adhesive from Toolstation "dot & dab" style to attach it & hope it never needs to come off !
                                          Nigel B.
