Adding text to metal
Home Forums Workshop Techniques Adding text to metal
  • #292340
    Curtis Rutter
      @curtisrutter61973
      The next project I'm looking at making requires letters to be put onto rings. I was thinking of punching these but wondered if anyone had any better ideas as the rings that would need punching are going to be a bit on the thin side
      Curtis Rutter
        @curtisrutter61973
        #292343
        Brian H
          @brianh50089
          Laser cut??
          #292344
          Nick Hulme
            @nickhulme30114
            Depending on the material masking and chemical etching may be an option.
            #292345
            Maurice Cox 1
              @mauricecox1
              I once wanted to put some lettering round a circle and did it on my lathe. Having turned the ring, in my case brass, I left it centred in the lathe and used letter punches guided by the slot in a quick change tool holder. The punches were held against the back of the slot by hand, and the clamp screws just brought down to lightly hold the punches down. The tool holder has to be squared to the work of course, and the punch payed on its side, adjusted to be at centre height. An indexing device was used to control the rotation between letters. A few experiments were needed to determine the amount to turn the work between letters. The gap varies depending on which letters are adjacent. A bonus was that I found it possible to give the punches an accurate second tap if needed. This was a one off job. If I was doing a lot, I think I would make some sort of sprung guides to hold the punches back and down in the tool holder slot. I the work is thin, then I think I would back it with some softish metal while punching, probably aluminium.
              #292347
              Maurice Cox 1
                @mauricecox1
                That should read " payed on its side" , sorry.
                #292348
                Maurice Cox 1
                  @mauricecox1
                  Both those postings will have to be "laying on its side". Spelling checker!!!
                  Double sorry.
                  #292358
                  David George 1
                    @davidgeorge1
                    I had a plate engraved by local laser engraver verry quick and didn't cost a fortune no damage, any font and depth of cut.
                    David
                    #292371
                    roy entwistle
                      @royentwistle24699
                      Have you got a local trophy engraver ? Or if in UK Timsons shoe repairers.  Try them
                      Roy
                      Edited By roy entwistle on 07/04/2017 09:50:18
