The slag inclusions are really too small for the drill idea but thanks for the thoughts Ady1.
How on earth did you think 'heat treating' would get rid of burrs on a laser cut part?
Tony
Ah perhaps I'd better explain the issue fully.
The bright mild steel that the laser cutter uses is quite ductile which I assume is so it can be readily bent in a press like the brackets for the grinding table.
The ductility means that the steel is a bit gummy when machining. When you drill a part the exit hole leaves a larger rag than normal and that has to be removed each time with a countersink or deburring tool, a bit of a pain but not the end of the world.
I would say the steel has been pickled to achieve the ductility as it has too low a carbon content for proper heat treatment.
After speaking to the heat treater we decided to try a heat and quench to see if it would remove the effects of the pickling.
As I mentioned above, that worked fine, small rags and the swarf tends to chip now rather than longer strings when turning. The downside is the cleaning up I've had to do.
Having worked on some of the parts and discovered how hard they are around the laser-cut surface, I assumed Gary intended the heat treating to reduce that hardness and allow burr removal subsequently.
To be honest I haven't had any issues with tool wear but I do try and make sure the first cut is deep enough to get all the way through the skin into clean metal.
I tried putting all the parts through my vibratory finisher after the acid dip, it didn't take off any of the inclusions but did give them a nice polished look
