Acton Works – overhauling Tube Trains in 1951
Home Forums The Tea Room Acton Works – overhauling Tube Trains in 1951
  • #37076
        Great old reel showing some interesting maintenance work and heavy machining.
        And some other interesting stuff (cars if you rewind to the start).
        #625822
        Dave Halford
          @davehalford22513
          Still to be found in the wild on the Isle of Wight.
          #625841
          john halfpenny
            @johnhalfpenny52803
            I don't think so Dave. Islandline is now re-engineered overground stock from Vivarail.
            #625886
            OldMetaller
              @oldmetaller
              What an amazing film, thanks Neil! I drove underground trains in the late '80's, a typical eight hour shift on the Met and Circle would involve 198 station stops, all of them 'service' stops, ie no tiptoeing in cautiously, all don't-brake-until-you-see-the-whites-of-their-eyes, balls-out stuff, the only way you could keep time!
              I went on to drive HST's on the 'big' railway, much less stressful!
              John.
              #625887
              Hopper
                @hopper
                And not a pair of safety glasses in sight, even when hot drop forging! I guess you just squinted a lot in those days.
                And great shot of the fabulous old Art Deco buildings at East Finchley station at the very start, glassed-in circular stairways and all. They don't build them like that any more, sadly.
                #625911
                martin perman 1
                  @martinperman1
                  Posted by john halfpenny on 22/12/2022 19:09:36:
                  Bedford to Milton Keynes has to Vivarail sets running but they have been taken out of service as Vivarail were maintaining them until this announcement Vivarail announces administration – Vivarail
                  Martin P
                  #625935
                    In the video that popped up next, An Overall Overhaul! (1934), they refurbish a London bus. I was much taken with the way the body was repainted.
                    Yes, that chap is pouring paint straight from a watering can, no rose. Excess paint collected in the trough below and reused.
                    Proof that all that fuss about master craftsmen applying primers and sanding down multiple coats in a clean room is a waste of time!
                    devil
                    Martin Cargill
                      @martincargill50290
                      SOD. The company where I served my time painted transformers (the big ones at the end of your street) using flood painting. The transformer tank was hung from a crane over a large trough (about 15' square). The trough had a pump, connected to a hosepipe and the operator hosed a coat of paint over the previously shot blasted surface.
                      Martin
                      #625946
                      Dave Halford
                        @davehalford22513
                        Changed only two years ago by the look of it
                        #625967
                        john halfpenny
                          @johnhalfpenny52803
                          Actually only this year(finally).
                          #626025
                          Harry Wilkes
                            @harrywilkes58467
                            Seeing those traction motors took me back to my days in the steel works changing the traction motors on one of the two material handling cars on the Blast Furnace was one of the worse jobs jn the steel work the top of the material handling car were level with the adjacent canal thus the rails on which the cars ran were level with the bottom of the canal and the canal wall leaked so always wet,wetter even more when it rained between the rails was a small inspection pit much like a concrete coffin without a lid so you got to squeeze into the water filled pit to disconnect the motor then struggle to get the rusty footbolts out drag the motor out and get to do it all in reverse
                            H
