Posted by Robin on 17/11/2017 14:59:10:
IIRC from my school days, acetylene has a bad habit of polymerising in to benzene with a vast release of energy from it's triple carbon bond. To keep it safe they dissolve it in acetone and the acetone is soaked into a something spongy, a bit like soaking nitroglycerine in to kieselguhr. If the tank gets warm of it's own accord you place it gently in the nearest ditch and stand well back. I spent a lot of my childhood throwing calcium carbide down holes in the ground followed by "water" and a match.
That is the sum total of my knowledge of acetylene, what gauge you use is beyond me
Hi Robin, I don't know how warm you are taking about, but if it reaches a significantly higher temperature than its ambient temperature, you must not move it at all. In the days gone by, the advice was to move it outside and cool it by putting it into a tank of water or by hosing it down with water. This advice was discontinued at least 15 years ago, maybe even 20, the reason being that it can be detonated by the slightest knock when it is in this state. This was discovered during a fire, when a fireman was moving a hot cylinder by churning it along the floor, but it then came to a small step of less than 50mm and as the cylinder rolled down it, it exploded and of course, killed the fireman. If you ever have a concern about an Acetylene cylinder getting hot, get everybody away from the immediate area and call the fire brigade pronto. Acetylene is the most explosive gas there is, however a Propane explosion will expand too five times its volume. (That's the volume of gas, not the size of the cylinder)
Regards Nick.
