My existing gearbox is for a 71 frame motor, the 3 phase motor I am planning to get is an 80 frame motor, and the shaft on the motor is 19 mm rather than 14 mm on the existing motor, so it won't fit.
What I was wondering about was, if I got a 30:1 gearbox for the new motor this should make everything fine for very slow rpm for the turntable of between 1-5. But would the VFD and the motor be able to increase the rpm of the turntable to 40 rpm with this amount of reduction?
Perhaps I would be better with say 15:1 reduction? I have 3 shafts with pulleys on to reduce the rpm, so I could change the machine if necessary to only use two of the shafts, which would increase the speed.
At the moment I will not need that much torque when the turntable is running at low speed. This is because at that stage I will be pushing the polishing lap across the mirror by hand.
The torque is needed when the lap rotates on the machine in a fixed place. However, eventually I would like to add a powered overarm so that the machine would push the polishing lap back and forth across the mirror. I could possibly use my existing motor and gearbox for this, it is better not to run the overarm off the same pulley system as the turntable but rather to have a second motor.
David
