Accurate hole location
Home Forums Clocks and Scientific Instruments Accurate hole location
Viewing 25 posts - 1 through 25 (of 35 total)
  • #288810
    Mike Crossfield
      @mikecrossfield92481
      I sometimes need to place holes in precise marked locations, and I wonder if the technique I've used for years is optimum.
      Say I want an accurate 1/4 inch hole at a scribed location on a brass clock plate to an positional accuracy of (say) 5 thou. I would start by dot punching the scribed location using an optical centre punch. I would then move to the drilling machine and use a short, stiff, CNC style centre drill to create a centre. I would then use a small drill, say 3/32, to create a pilot hole, and follow this up with a 7/32 drill, and finally a 1/4 reamer (hand reamer, used in the drilling machine). Sometimes I get the accuracy I want, sometimes I don't.
      Would it be more accurate to omit the somewhat flexible pilot drill, or is there a completely different sequence which would lead to more consistent results?
      Mike Crossfield
        What is the optimum technique for placing a hole in a marked location?
        #288811
        MalcB
          @malcb52554
          Hi Mike,
          By the initial sound of it I dont think you have a milling machine, so my thoughts depending on your cash availability, would be to look out for a half decently calibrated dials compound table for your drill.
          I would then eliminate the variables from marking out, punching and picking them up and go for indexed pitching from the calibrated hand wheels. Easy to map out your co-ordinates on paper, but you will need an accurate start datum.
          Edited By MalcB on 14/03/2017 17:56:21
          #288812
          Emgee
            @emgee
            Mike,
            You could clamp a hardened 7/32" drill guide on the exact centre location and drill 7/32" direct without using a centre drill or the 3/32", if securely clamped the guide will give you the accuracy required for the drilled hole so you should heve a good chance of the reamed hole being where required.
            Emgee
            #288813
            Mike Crossfield
              MalcB
              I do have a milling machine equipped with DRO, and I often use it for coordinate drilling. My question related to drilling holes starting from scribed locations, such as those created when planting clock trains.
              Emgee
              Using a hardened drill guide would be specific to only one size of drill, so not a general method, and how would one go about accurately positioning the guide over the scribe marks?
              #288814
                When I need to pick up scribed marks I use the mill with a wobbler (sticky pin will do) to locate the point of intersection, then Lock the table and zero the DRO. Spot drill straight onto the lines as no need to punch and then stub drill out to reamer size then ream under power, twist drills will do if you don't have stub length.
                7/32" sounds a bit small for 1/4" reaming try 15/64"
                #288816
                Tony Pratt 1
                  @tonypratt1
                  +1 for 'sticky pin'
                  Tony
                  #288817
                  Mike Crossfield
                    Thanks Jason, that sounds like an improved approach which eliminates the pilot drill, which I had doubts about.
                    I have a wobbler of the George Thomas variety, but my deteriorating eyesight makes it hard to line it up really accurately with scribe marks. I'll have to try harder with magnification and better lighting
                    #288818
                    duncan webster 1
                      @duncanwebster1
                      If you want to be posh you can buy/make an optical centre finder, a sort of bent microscope that fits in your milling machine spindle, but you can do better than 0.005" with a sticky pin and a loupe
                      #288819
                      Mike Crossfield
                        Thanks for that Duncan. I like the sound of the optical centre finder. I feel another project coming on!
                        #288823
                          Mike,
                          Reverting to more traditional horological technique:
                          With a pair of crossed scribe lines [from the depthing tool] you should be able to feel the intersection with a sharp scriber … pick-up and deepen that intersection with the scriber, then use a 'spade drill' to open it up to a nice conical depression. … Then proceed as previously discussed.
                          • If moving-up to a conventional twist drill, it's important to get the diameter of that depression big enough to contain the chisel edge!
                          • It's very convenient to make your spade drill from a swivel-topped screwdriver.
                          Edit: this is the shape of spade drill, 'though of course you don't need carbide for brass clock plates!
                          https://www.eternaltools.com/carbide-spade-drills
                          Edited By Michael Gilligan on 14/03/2017 20:01:53
                          #288829
                            Simple optical finder design here (+ an optical centre punch)
                            http://www.model-engineer.co.uk/news/article/an-optical-finder/24734
                            From MEW issue 1, no less!
                              Another thought, I would use s 15/64 drill before reaming (assuming it was a good one that drilled close to size).
                                Posted by Neil Wyatt on 14/03/2017 20:20:56:
                                Another thought, I would use s 15/64 drill before reaming …
                                In a brass clock plate, I would use a horological [five-sided] cutting broach, not an engineering reamer.
                                Roy M
                                  @roym
                                  Here is how we used to drill and ream holes over any distance, usually better than .002" when making airframe jigs in the aerospace sector using drill bushes. You will need two 'drill bars', essentially these are gauge plate 150x 20x 12. With a slot for clamping. In one end is a reamed hole either 12mm or 1/2" depending upon the O.D. of your slip bushes. You pick up your first position using the optical centre finder, clamp the bar in position, then drill and ream to size. The second position is established by using a dowel in the fixed drill bar, then, with a dowel in the second drill bar, position using either a micrometer or inside mic., clamp bar in position, then drill.
                                  I still have all the kit to dispose of after 20 odd years! Roy M.
                                  #288844
                                  duncan webster 1
                                    @duncanwebster1
                                    Posted by Neil Wyatt on 14/03/2017 20:19:35:
                                    The one I remember had lenses and graticules and all sorts of other complicated stuff, either ME or MEW. I suspect you could use a USB microscope, but that's the end of my knowledge
                                    #288848
                                    Emgee
                                      @emgee
                                      As you have a mill with a DRO why not clamp the work clear of the table surface then use an edge finder to locate the hole by XY table movements to match the hole centre co-ordinates from the 2 edges, lock the XY axis and drill and ream the hole.
                                      Emgee
                                      #288856
                                      JA
                                        @ja
                                        Quite a few years ago I had the same problem and thought long and hard about solving it. In the end I made an alignment microscope based on a design by D A G Brown & R A Stephen. The optics were not cheap and the manufacture was interesting (there is a Whitworth based microscope thread). However the resulting instrument can locate to better than 0.001" with ease. There are a few difficulties such as the work piece has to be very well lit and that it can be difficult to get one's head in the right position to look through it. [There are two pictures of the "thing" in one of my albums]
                                        This together with a good DRO gives an order of accuracy better than one usually needs. Therefore it is used only when really needed.
                                        As for the rest of your question I think it is jig boring using a small centre drill to locate/start the drilling of the next hole.
                                        JA
                                        Edited By JA on 14/03/2017 23:24:59
                                        Edited By JA on 14/03/2017 23:28:40
                                        Edited By JA on 14/03/2017 23:30:13
                                        #288859
                                        Ady1
                                          @ady1
                                          I got a battery operated engraver from TKmax recently
                                          At the time it was a "might be useful" moment but it is good for making a dimple exactly where you want it because it has a tiny rounded diamond tip
                                          #288863
                                          Rod Ashton
                                            @rodashton53132
                                            Some years back the spinning laser pen was popular. Just a trammel type arrangement with the pen angled down and adjusted in "Z" until aligned by the convergence of the beam, or the described circle. Good for centering over round bars as I recall. ref. https://www.youtube.com/watch?v=q_aa4rANib0
                                            #288867
                                            Mike Crossfield
                                              Ok. My overall take is to pick up the scribed mark using a wobbler or optical device on the mill. Use a s spotting drill to create a centre, follow this up with a stiff reaming size drill (no pilot), then ream.
                                              Thanks all
                                              #288869
                                                Posted by Rod Ashton on 15/03/2017 06:41:07:
                                                Or MEW 253…
                                                Chris Evans 6
                                                  @chrisevans6
                                                  Why complicate a simple job ? Plasticine and a pin to make an "Industry Standard" sticky pin is all that is needed. I have seen them used on a jig boring machine to pick up lines when we could not fit an Icky ball to the job. You will certainly be within a couple of thou.
                                                  #288887
                                                  Steven Vine
                                                    @stevenvine79904
                                                    Please can someone tell me how this plasticine and pin method works? Where does the plasticine go, and where does the pin go?
                                                    Thanks
                                                    Steve
                                                    #288891
                                                      I'm sure there is a video on youtube somewhere but this one of a wiggler will do, go to about 55 secs intoi the video where they show the pointed probe.
                                                      For a stick pin put a short stub of bar into your collet, bit of plasticene or blue tack on the end and the blunt end of your pin in the bluetack, basically the bluetack is the ball joint that you have on the wiggler. Run at slower speed with a pin.
                                                      Edited By JasonB on 15/03/2017 10:20:03
                                                      Edited By JasonB on 15/03/2017 10:21:39
