For some reason, which I don't fully understand, I have set myself the task of renovating an elderly Italian piano accordion. It has suffered from damp storage, but was cheap and, being from one of the better makers, is worth restoring. Like some expensive Italian classic cars, it looks pretty, is full of ingenuity, some 'engineering' is rather suspect, its execution leaves a bit to be desired, and it seems to have been designed to corrode. Fortunately, it contains nothing electrical…
The thing contains slides, to select reed banks. These are thin, delicate strips of aluminium alloy, sliding in aluminium alloy channels, held captive by an aluminium alloy plate – an aluminium alloy sandwich. There's quite a bit of corrosion, which has caused the slides to be stuck. I've mechanically cleaned off as much corrosion as possible, but there will be traces of oxide left in corrosion pits in the material.
Small brass screws have been used in aluminium, with corrosion making some (so far) stuck fast.
Q 1. Is there a non-aggressive chemical treatment to 'kill' aluminium corrosion? It must not leave an oily or sticky residue. Anodising isn't practicable.
Q 2. Any suggestions for removal of corroded-in brass screws (which seem to be made from crumbly cheese)? I'm hoping to release them chemically, and preserve the screws, so not wanting to drill them out.
Q 3. Accordion repairers warn against oiling any of the mechanism because of the risk of fluff and dust build-up. In any case, oil or grease would produce too much drag in the slide mechanism, but would a PTFE-based 'dry' lubricant work, or does it eventually peel off surfaces? Ideally, something is required to prevent corrosion.
