I wanted to know how useful is the cutting paste when drilling. I saw a test on YouTube but I didn't find it conclusive. Also I have a different paste. So I decided to make a test setup with my press drill. I attached a lever with a weight to have the same pressure on multiple drills.
I tried also WD40 lithium and the way oil that I'm using for the lathe.
The heller paste is available on Amazon. I repeated the test for two 5mm HSS drill bits made in Ukraine. I made consecutive drills in different condition, without paste, with paste, with oil and with grease. I cleaned the drills with acetone when changing the substance. Here are the results:
Conclusions:
- When paste is used the drilling time decrease to 64% and 71%.
- Drilling bit wear during test was negligible (important for test relevance)
- Oil and grease have no effect
- Large cutting time dispersion between different bits.
I hope this helps for others who have the same dilemma.
Edited By Sonic Escape on 25/06/2023 17:36:57
