Hopper, the displacer started its life as a bit of rebar, bored out, and turned down to 11.25 mm, the hot end is a steel disc brazed in, cold end aluminium loctited in, that size leaves a gap of .93 mm. AAA battery would work, its diameter is10.25, that would give a gap of 1.43 mm, it would also be thicker than my home brew tube at just over .005" thick (think I made about 3 of them before I got one without a hole in the wrong place).
Neil, the insides of lots of thing end up on the outside around here, hasn't hurt me yet. Want an aluminium cylinder 30 mm x 165 mm, try a used Paslode fuel cell. When the builder finishes with the cell its still got enough gas to fill my little pencil torch a number of times, then when its empty you can open it, and take the gas bag out of it. I have used these as displacers, but the way I run my motors, they tend to melt. Ian S C
