Posted by Steviegtr on 12/06/2020 22:56:30:
Are you sure of the power output. 1 bhp per cc.
Steve.
One of the ultimate limits to power from combustion engines is that air/fuel cannot pass a hole/port/valve faster than sound speed.
The relation of maximum port area to cylinder volume is helped by being a small cylinder.
Let us say a worldbeating 2.5ccm engine has a port area of max 50 square and can pass air /fuel that gives 2.5 horsepower.
If we enlarge all linear dimensions by 1.38, we get 6.5 cubic cm and get 95 square mm port in very good accordance with the mentioned power of 5hp for a 6.5 cubic engine.
It is the cube/square law at work.
Edited By Niels Abildgaard on 13/06/2020 10:22:52
Edited By Niels Abildgaard on 13/06/2020 10:23:48
