A variable Lead threading attachment. Author Ted McDuffie
Home Forums Model Engineer & Workshop A variable Lead threading attachment. Author Ted McDuffie
Viewing 16 posts - 26 through 41 (of 41 total)
  • #122430
    Sub Mandrel
      @submandrel
      Hi Mike,
      i was musing on whether or not the errors intoruced by using imperfect gear ratios are significant enough to warrant using such a device for fasteners and otehr threads that just need to work, rather than be highly accurate (as in a micrometer stop, leadscrew or similar).
      jacques maurel
        @jacquesmaurel42310
        The anwer to the 2 questions of Ady 1 is yes.
        Answer to Michael Williams: the drawing 1 is just here to explain the principle.
        J Maurel
        #122542
        Ady1
          @ady1
          I had a feeling about this gadget and ran it through some animation software I have
          The problem is that the parallelogram describes an arc as it moves… but the slide won't let it do that and forces the cutting tool part of the unit to move in a parallel fashion… so the geometry either jams up or something has to give(break)
          The only solution I can see is where the little arm bolts to the big arm, you need a slot, not a hole, for that bolt as the geometry alters, and this may mess up the thread
          It's a bit like a shaper drive, there's a slight arc as the drive powers the shaper head and they use a slot, not a hole, at the top of the drive
          Anyway, if anyone ever builds one of these things for real… then we'll find out
          #122555
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Hi Ady1 ,
            To make this thing work at all the lower pivot on the combining lever has to run on a long swivelling radius arm anchored at the other end to some fixed point .
            Could work with a slide instead but either way the geometry is imperfect .
            MikeW
            Edited By MICHAEL WILLIAMS on 18/06/2013 10:32:37
            #122578
            jacques maurel
              @jacquesmaurel42310
              I've made a sofware simulation using Solidworks and the kinematics application motionworks, with the example already given (20 tpi from 1mm standard lead) the error for 90 mm thread length machined is about 0.004mm, less than the lead screw tolerance!
              J Maurel
              #124041
              jacques maurel
                @jacquesmaurel42310
                I've made a short video showing the attachment at work: cutting a 3/4" BSP thread (14TPI) on a metric lathe (actual lead 1.5mm).
                J Maurel
                #124170
                jacques maurel
                  @jacquesmaurel42310
                  Here is a link to my website, I've gathered some informations on the attachment and there is a drawing and a photo showing a threading machine from the eighteenth century using the same principle: **LINK**
                  J Maurel
                  #124266
                  Gary Wooding
                    @garywooding25363
                    Posted by Ady1 on 18/06/2013 03:11:03:
                    I think you're wrong, because it's not a parallelogram at all. The schematic diagram is not particularly good, and is certainly not clear.
                    Point D is attached to the saddle via the topslide, and item 2, which holds the tool, slides across it as the lever AC rotates about point C. The link DB (item 4) is is free to rotate at both ends, so, although the vertical distance between point D and item 2 remains constant, the vertical distance between points A and B reduces as the lever rotates about point B, as does the vertical distance between points C and A.
                    #124541
                    Ted Clarke
                      @tedclarke82795
                      I have built a version of McDuffie's inventrion and checked its accuracy. My version is described in my article for the web journal Modern Microscopy: **LINK**
                      Ted
                      #160607
                      Marcus Bowman
                        @marcusbowman28936
                        Jacques,
                        I have sent you a PM.
                        Marcus
                        #160641
                        Ady1
                          @ady1
                          I'm still not convinced about this
                          Anyone got it to the stage where you slap it on the lathe and run a thread out yet?
                          #160646
                          Neil Lickfold
                            @neillickfold44316
                            Jacques,
                            So if the sliding tool holder was set on angle, would it then be possible to turn tapered threads?
                            Have you got pictures showing your setup without the chip cover ?
                            #160686
                              Has anyone got a spare copy of the issue of MEW with this in?
                              Ted would dearly like to have a copy, but there are no back issues left.
                              Please pm me or email if you can help.
                              Thanks
                                My apologies, and thanks to those who have already replied. I should make it clear it is Ted Clarke who needs a copy of the MEW with his article, "Adjustable Threading Feed Attachment for the Lathe" it is Issue 204, not Ted McDuffie who wrote the earlier article.
                                I have asked before, but if anyone does have a paper copy, please do let me know.
                                Thanks
                                Brian Wood
                                  @brianwood45127
                                  Hello Neil,
                                  Does he want the whole magazine or just a copy of his article?.
                                  I don't want to part with my copy, but I am quite willingly to scan and email from it.
                                  Regards Brian
                                  #160717
                                    He wants a paper copy. thanks for the offer.
