A usefull tool?
A usefull tool?
Home Forums Workshop Tools and Tooling A usefull tool?
  • #116535
    keithmart
      @keithmart
      Hi
      I found this you tube vice, which was apparently done as an april fools trick, but could be a usefull idea.
      What does the team think?
      regards
      Keith
      Leeds UK
      keithmart
        @keithmart
        #116540
        Andyf
          @andyf
          Dunno if it's an April Fool trick; they seem to be selling it online here.
          Andy
          #116543
          Andyf
            @andyf
            Oops! I've just clicked on the Further Info link…..
            Should have realised, 'cos the table is flat, with nothing to secure the radial arms in which the jaws run.
            Other than that, it's pretty plausible.
            Andy
            #116544
              Lee Valley have an April Fool Tool every year.
              Personally I much prefer this one
              Andy, the arms actually have a pin in the end that locate in the holes around the hub.
              J
              Edited By JasonB on 10/04/2013 13:06:53
              #116547
              Bazyle
                @bazyle
                Looks easy enough to make. At last I have a use for that diff crown wheel I've got in the scrap box.
                Jason, wait a few weeks and that plane shroud will be a mandatory HSE requirement, get your order in now.
                Edited By Bazyle on 10/04/2013 12:50:06
                #116554
                John McNamara
                  @johnmcnamara74883
                  Hmmm?
                  Next time I want to make a thingamajig or a wigwam for a gooses bridle I will get one…….
                  Cheers
                  Macka
                  #116556
                  Robbo
                    @robbo
                    The part number should give you a clue AF2013 April Fool 2013!
                    Phil
                    #116583
                    Sub Mandrel
                      @submandrel
                      Andy – there are holes in eth centre plate into which the arms peg.- perhaps it is a real prototype!
                      I like 'if you're not intio prime numbers…'
                      mark mc
                        @markmc72333
                        To me it looks like a big scroll chuck, would actually be quite handy at times.
                        #116626
                        Sub Mandrel
                          @submandrel
                          I just figured out the catch… to hold irregular objects (that chair seat for example) the dogs need to move independently, and they don't. But you could hold symmetrical objects or produce custome jaws for odd shape, only worth doing if you are making a lot though.
                          Ian P
                            @ianp
                            To my eye they do appear to be independenly movable, firstly by having them set to the aprox position before engaging with the central gear, and secondly it seems to show the jaw nuts are some sort of half nut arrangement.
                            Seems a lot of trouble just for an April 1st joke.
                            Ian P
                            #116680
                              For anyone who has not yet found it;
                              here is a link to the ten AFD products they have made so far.
                                Sorry folks,
                                That link may not work
                                … if it doesn't,just put AFD in the search box.
                                Sub Mandrel
                                  @submandrel
                                  Just looked at all the different tools. If you read the 'second pages' you'll discover they all really work, although they are impractical (except the story tape which is real).
                                  I also notice that they are all beautifully made.
                                  Bazyle
                                    @bazyle
                                    I like the pocket dovetail tool illustrations of where to use it. As engineers we could always make some of these.
