Posted by Ian S C on 22/04/2012 07:42:35:
You can use a car generator instead, with a regulator, does not need a voltage supply to start charging, its not so efficient, an harder to find these days, but quite a good way to go. Ian S C
Agreed, Ian, a generator is not as efficient, and lacks the built in regulator, but at the time I was toying with the idea for camping, and alternators were not so plentiful and cheap as is the case today.
We did try an alternator temporarily on a Briggs and Stratton fourstroke, without any excitation, and found that it would, infact, self-excite, but the B&S then started to labour, even without a load, and as it was only a test the project was discontinued.
All this is a far cry from the original purpose of charging 2000mAH NiMh cells, so we'll let it go at that!!!
How hard would it be to locate a bicycle hub generator and arrange a suitable drive system??
donhe7
Edited By Donhe7 on 22/04/2012 09:00:53
Edited By Donhe7 on 22/04/2012 09:01:38
