I never went to a scrap yard before but last week I decided to check if there is something interesting there. There is a small one close to me. After visiting it I quickly concluded that I will never have the old problem of buying only 6m long tubes/bars.
Next day feeling more enthusiastic I went to a larger scrap yard that is 6km away. This time it was far more exciting. The day before the mechanical engineering college decided to dump many of their old Romanian made machines. The yard was full of huge lathes, different mils and all sort of more specialized machines. They even bring a few trucks while I was there. It was a little painful to see how they were unloading them. The ground trembles when a 2 ton machine is dropped from 3 meters. And then they were smashing the machines into pieces. Some of them looked quite good in my opinion. They were not used to much since they were not from a factory. This is a small milling machine:
But the biggest surprise was when I found an FUS 250 milling machine. This is exactly the type of mill I bought a few weeks ago! And it is a rare type. Mine was missing a hook. The hook is like a big screw. On the milling machine table I found a similar hook already unscrewed!!! This is extreme luck!
Next day I went again with almost all my tools ready to disassemble all kind of interesting parts. There was one machine so large that you could walk inside it. This one is a FU 32. It is very heavy. I think you can see a clutch inside:
This one is a smaller mill. A friend of mine wanted to buy it but they overturned it by mistake and broke it. The milling head fell apart.
This one is a machine for making grooves. They were 3 of them:
So many interesting things! I was jumping from one machine to another and I couldn't decide what parts to remove.
I was never been so full of oil and dirt. The were many cranes in the yard and you had to be careful with heavy items moving above you. They didn't seems to care about safety. They were melting coper from motors and transformers with torches. The smell and fumes were horrible, I don't know how they can work in that place. I saw a large electric panel with many mechanical timing relays. The ones that have a synchronous motor and are usually in transparent enclosures. They burned everything hoping to recover some coper. I think this is stupid.
First I wanted to take a few slides like this one:
Then I realized that it is very unlikely to use them. And they are very heavy. So I started to remove all kind of small parts. I even found something that ca be used as a dog. This is part of the "prey":
The most important thing that I bought was the head of the FUS250 milling machine. Now I have a spare one. I measured it and it had a runout of 20µm.
But it has a different collet type. It looks like Schaublin B32. Unfortunately they cost as much as cocaine. When available.
Watching the insides of these machined increased a few times my limited knowledge of mechanics. Half a day flew without notice. This is Disneland for adults!
