In order to sharpen my lathe and shaper tools, I have made do (thus far) with an extended guide on a 6" grinder, fitted with a simple sliding table (and angle plate). I've wanted something better for a while and had considered the various options (Harold Halls 'rests' for instance).
However, I have been very fortunate this weekend to acquire a part built Stent T&C for a reasonable price. The main castings have been machined and a lot of the 'heavy lifting' work seems to have been done. I'll know more when I dissemble it and take a closer look next week. I have to decide how to mount the motor and make various small fittings/hand wheels etc, including the work-holders (I've the castings for the main work holder but no centres for instance).
I already have copies of the ME (1991) articles on the Stent build and also MEW 137 (on a "Super" Stent version) and will sit down for a good read over coffee later. I therefore have most of the available reference materials and will also re-read the various 'Brooks-Stent' material (e.g. Gadgetbuilder) available (which was another of my possible T&C options before this one came along). However, any recommendations and/or comments in this area would also be most welcome!
I will obviously need a set of grinding wheels and know that the 'white' aluminium oxide wheels used to be the norm. However, these days there are also 'diamond' wheels available (from Arc for instance).
I still expect to rough out my cutting tools on the 6" grinder by the way and I also sometimes "pre-form" them with either a Dremel or an angle grinder. So the Stent will initially just be used to maintain my existing lathe and shaper tools and hopefully thereby get better 'repeatability' and sharper tooling. However, I also want to start learning to sharpen milling cutters, as I now have quite a few that probably need it.
So my apologies for the long pre-amble but my questions are these:
What would be a good "starter" set of grinding wheels (suitable for the Stent) and what should I get – just diamond or just 'white' to begin with. What are the pros & cons of each? Should I adopt a particular "standard" for my wheels at the outset (wheel diameter, mounting holes etc?) And of course where would you suggest I buy them?
In other words, what would you recommend if you were starting over & buying these items for a Stent type T&C from scratch?
IanT
