I can prove this.
It's down to the power of the MKI eyeball.
Take centering a shaft on the mill for cutting a keyway as an example. Many people have many different ways and gadgets to do it but the MKi eyeball still comes off the best.
Take a good look at this picture.
This shaft was lined up exactly central by touching on both sides with a dowel pin and splitting the difference on a DRO so backlash wasn't an issue.
A milling cutter was just allowed to kiss the surface on the left, you can see the 'butterfly' is equal.
It was then moved along at the same zero setting, then moved sideways by one thou, 0.001" and a second mark made, the one on the right.
It's a mile out, so no need for fancy gizmo's, just touch down on the work, look at the spot and trust the MKI eyeball, unless you need to go to specsavers.
