Here are a few further comments on the machining side. Sorry, if I missed anybody out.
JohnS: Yes, I was using a key. When I put the slitting saw on the arbor I did hesitate, but decided that since this was a 6″ cutter, and I would be taking reasonable cuts, 10mm, it seemed better to use a key. May be I was wrong. In my limited experience when a slitting saw spins on a deep cut it breaks anyway, as I’m not quick enough to knock the power feed off before catastrophe.
Norman: I agree, but the casting is 1.5″ thick at worst; I’m not that fit!
KWIL: Mating with the table was pretty good, I did run a file over the bottom of the casting, but it wasn’t really needed. The third clamp played no part, as there wasn’t one.
What I will say in my defence is that it was never my intention to completely separate the casting with the slitting saw.
JasonB: Well spotted, there’s my mistake, no wonder they’re called saws rather than cutters.
At no time did the saw get hot, or even warm. I dropped the clutch after each pass to check, and when I was picking up the pieces they were all cold. The cut surface is pretty flat; I can just get a 1.5 thou feeler gauge between a steel rule and the surface if I push a bit.
Les: Sound theories but I don’t know which one might be correct either, although I lean to the second one.
RichardP: I can assure you that the clamps were correctly fixed. My mill will run in either direction; the control panel makes no claim as to which it considers forward or reverse. Even if I reversed the spindle direction, and the saw, surely it would still tend to lift the casting. The only way for the saw to push the casting down is to climb mill. I don’t understand the comment on the rule; the numbers are purely arbitrary, the ruler is just to give a feel for scale. It happens to be at about 6″ because that’s where the rule was in balance on the casting.
Let me re-iterate that it was not my intention to separate the two parts of the casting with the slitting saw, but simply to ease the effort required by the hacksaw. Here’s what I think happened. On the final cut I didn’t leave enough metal, and as the cutter reached the end of its cut the casting moved, possibly a la Les’s theory, and momentarily trapped the cutter, causing it to shatter, before the casting itself factured. On the second part I left about 6mm of metal and everything worked perfectly. No funny noises, hot blades or shattering experiences, just a nice clean cut and a couple of minutes work with the hacksaw to finish off.
Edited By Andrew Johnston on 05/10/2011 17:39:15
