There are several ways to absorb the output of a wheel (or two) – favourites in industry include driving a friction brake, stir water or oil, whirl a fan, or generate electricity. The last is probably the easiest to measure, as the current and voltage are easy to measure, just multiply them for Watts. With modern belts, arranging a variable pulley system would also be simple, for the fairly low power outputs involved.
And it is much easier to compare outputs, than to be sure what the output is, as none of the stuff involved is 100% efficient.
Hope this helps – Tim
Edited By Tim Stevens on 17/12/2021 18:40:10
